ASR1002 bridging
I have a ASR1002 router which i needs to connect it with two firewalls. Can someone give a solution for this?
I tried to use bridging, but bridging is not supported I believe.
Appreciate your help.
Thameem
jessedavis
Hello Thameem,
The ASR supports 802.1q encapsulation on sub-interfaces. It's also possible to create Layer 3 port-channels with the ASR.
The sub-interface configuration example is below -
interface F0/0/.100
encapsulation X <--- VLAN tag value
ip address x.x.x.x
The port-channel configuration example -
interface Gi0/0/0
channel-group 1 mode active
interface Gi0/0/1
interface port-channel 1
ip address x.x.x.x
Hope this helps,
Jesse
