ASR1002 strange logs
ez9
I have an ASR 1002 router with RP1 and ESP10 that lately it shows some strange logs. Is it possible to decode these logs to understand if this is a configuration error or a bug in the IOS?
I found some bug references about NAT configuration but this router not having any NAT commands enabled.
The errors are the following:
%IOSXE-3-PLATFORM: F0: cpp_cp: QFP:0.0 Thread:049 TS:00000005425423223734 %INFRA-3-INVALID_GPM_ACCESS: Invalid GPM Load at 8066edd1 HAL start 3fc0 HAL end 409f INFRA start 4070 INFRA 40a0 NET 34082 -Traceback=1#567e5bd5cdb03517b654f39592cf59eb 8085dc9f 8085e154 80808a32 80020884 8066edd1 80440cad 8084925c 8301dc60
000483: May 15 15:04:20.154: %IOSXE-3-PLATFORM: F0: cpp_cp: QFP:0.0 Thread:049 TS:00000005425423538207 %INFRA-3-INVALID_GPM_ACCESS_INFO: 80440cad 0002f9a0 00000014 00008300 8a1cdc00 c0002a88 00004240 c0002288 00002504 7b8300b8 0003409a 80000000 00001420 00004400 b844682d 000000ff
000484: May 15 15:04:20.154: %IOSXE-3-PLATFORM: F0: cpp_cp: QFP:0.0 Thread:049 TS:00000005425423803080 %INFRA-3-INVALID_GPM_ACCESS_DATA: 432a4fc933e60352 5d1ea07a43ea9d83 1e0ad4f1ea4e8755 c76c39c132ce351f 840793bde2f0aade 1b84586d9f3b33f4
marce1000
             - FYI : https://bst.cloudapps.cisco.com/bugsearch/bug/CSCta78964
 M.
Thanks for the answer. The router's version is the following asr1000rp1-adventerprisek9.03.16.10.S.155-3.S10
The bug is for the 12.2.x version. Maybe the this issue is not resolved yet. Is there a way to analyze tracelogs or core files to find the root cause?
 - In any case you should evaluate the issue against the latest advisory software version , if that does not help , engage TAC ,
 M.
