ASR1002-X 16GB router
whitegrape
Hi Guys,
Wondering anyone has issue on memory. I have 16gb router but I'm unable to get more than 3.5gb processor memory. Redundancy mode is none. any idea?
cisco ASR1002-X (2RU-X) processor (revision 2KP) with 3422740K/6147K bytes of memory.
Processor board ID
6 Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
16777216K bytes of physical memory.
6688767K bytes of eUSB flash at bootflash:.
Redundant System Information :
       Available system uptime = 45 minutes
Switchovers system experienced = 0
              Standby failures = 0
        Last switchover reason = none
                 Hardware Mode = Simplex
    Configured Redundancy Mode = Non-redundant
     Operating Redundancy Mode = Non-redundant
              Maintenance Mode = Disabled
                Communications = Down      Reason: Failure
Current Processor Information :
               Active Location = slot 6
        Current Software state = ACTIVE
       Uptime in current state = 45 minutes
                 Image Version = Cisco IOS Software, ASR1000 Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.5(3)S, RELEASE SOFTWARE (fc6)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Sun 26-Jul-15 21:02 by mcpre
                          BOOT = bootflash:asr1002x-universalk9.03.16.00.S.155-3.S-ext.SPA.bin,1;
                   CONFIG_FILE =
        Configuration register = 0x2102
                Head    Total(b)     Used(b)     Free(b)   Lowest(b)  Largest(b)
Processor  7FB851FF0010   3504656768   398432652   3106224116   3105249280   3105203428
 lsmpi_io  7FB8517ED1A8     6295128     6294304         824         824         412
Could you please set the following variables in the Rommon mode:
unset ENABLE_VTX
DISABLE_VTX=1
sync
Once this is done, boot up the router and let me know if that helps.
If i recall correctly, starting version XE 3.8, there is a separate memory space for VM's is allocated for 3rd party application hosting on the ASR1k. Thus resulting in less memory being allocated for IOSd process.
Also, Note that You wont be able to see 16G memory being available as part of show memory summary or statistics output. If you notice the command output that i requested before, it clearly shows 16G memory.
Memory (kB)
Slot   Status    Total            Used (Pct)             Free (Pct)     Committed (Pct)
RP0 Healthy 16304880 2451508 (15%) 13853372 (85%)   5193816 (32%)
Hope this Helps.
--Vinit
8 Replies 8
whitegrape
Hi guys,
Any help will be deeply appreciated.
Whitegrape.
whitegrape
I wondering whether it is due to my default 5gbps esp license causing unable to view full 8gb router memory?
Vinit Jain
Could you please check the output of below command:
- show plat software status control-processor brief
- show platform
--Vinit
Hi Vj,
Thanks for your reply! Really appreciate it.
Kindly find the below output from the router.
#show plat software status control-processor brief
Load Average
Slot Status 1-Min 5-Min 15-Min
RP0 Healthy 0.47 0.58 0.62
Memory (kB)
CPU Utilization
Slot CPU User System Nice Idle IRQ SIRQ IOwait
RP0 0 43.45 11.08 0.00 43.85 0.00 1.59 0.00
1 1.50 0.30 0.00 98.20 0.00 0.00 0.00
2 0.30 0.10 0.00 99.60 0.00 0.00 0.00
3 0.60 0.10 0.00 99.30 0.00 0.00 0.00
SPARKS-ASR1K-X#show platform
Chassis type: ASR1002-X
Slot Type State Insert time (ago)
0 ASR1002-X ok 02:21:24
0/0 6XGE-BUILT-IN ok 02:20:05
R0 ASR1002-X ok, active 02:21:24
F0 ASR1002-X ok, active 02:21:24
P0 ASR1002-PWR-AC ps, fail 02:21:00
P1 ASR1002-PWR-AC ok 02:21:00
Slot CPLD Version Firmware Version
0 14012203 16.3(2r)
R0 14012203 16.3(2r)
F0 14012203 16.3(2r)
caroyy
unset ENABLE_VTX
DISABLE_VTX=1
sync
Memory (kB)
Hope this Helps.
--Vinit
Hi VJ,
Thanks!! Its working! How can i repay your kindness?
Im now seeing full 8gb from the router memory.
I hope in future others can solve their problem by reading this article using your solution.
Thank you for explaining the new XE 64bits memory architecture. Now i see the reason why the vtx is enabled in order to run other vm on it.
cisco ASR1002-X (2RU-X) processor (revision 2KP) with 6934957K/6147K bytes of memory.
Processor board ID
0K bytes of WebUI ODM Files at webui:.
SPARKS-ASR1K-X#show plat software status control-processor brief
Load Average
  RP0 Healthy   0.47   0.82   0.54
Memory (kB)
  RP0 Healthy 16304880  2486140 (15%) 13818740 (85%)   8589120 (53%)
CPU Utilization
  RP0    0  42.30  10.80   0.00  45.10   0.00   1.80   0.00
         1   1.90   1.20   0.00  96.90   0.00   0.00   0.00
         2   0.80   0.80   0.00  98.40   0.00   0.00   0.00
         3   1.80   1.60   0.00  96.60   0.00   0.00   0.00
caroyy.
Hi Caroyy
Nothing to repay. Glad i was able to help and more than that, I'm glad its working for you now.
Have a great day.
--Vinit
Hi VJ,
Have a great day too! :)
caroyy.
