ASR1002
peter2hughes
how many SPA's can an ASR1002 support with  SIP10
Reza Sharifi
Cisco ASR 1000-SIP10—This SIP supports:
4 half height (¼ Rate or full rate or combination) SPAs with up to 16 ports per SPA
2 full height (¼ Rate or full rate or combination) SPAs with up to 32 ports per SPA
2 half height and 1 full height comb in at on that does not exceed 64 ports
Up to 10 Gbps of oversubscription
http://www.cisco.com/c/en/us/td/docs/routers/asr1000/install/guide/asr1routers/asr1higV8/asr1SIP4.html
Reza
Many Thanks , should have qualified my question better , how many 10Gig SPA's  , I think its only 3 but need clarification
Peter,
I think, 3 is correct but obviously with SIP10 you don't want to put 3 10Gig cards in the chassis as the total aggregate bandwidth is 10Gig (SIP10).
