03-07-2012 02:32 AM - edited 03-04-2019 03:34 PM
Our client have a new ASP1004, and when power on , after IOS loaded, it show
%CMRP-3-IDPROM_ACCESS: Failed to access or process IDPROM 'midplane': Invalid argument -Traceback= 1#3062921b41df6c7cc68a48d54ceee889 errmsg:ECA1000+2160 :10000000+2C414 :10000000+4BD84 :10000000+38E00 :10000000+3A4AC c:E421000+1E938 c:E421000+1EAE0 Mar 7 01:53:57.423 R0/0: %BOOT-0-APP_STARTFAILCRIT: Failed to launch a critical process cman.
What is the reason power failed , software problem or hardware problem? Thanks.
Below is the log:
Current image running: Boot ROM0
Last reset cause: PowerOn
Last reset at: Wed Mar 07 01:50:20 UTC 2012
ASR1000-RP1 platform with 4194303 Kbytes of main memory
Located asr1000rp1-adventerprisek9.03.04.02.S.151-3.S2.bin
Image size 311474488 inode num 12, bks cnt 76044 blk size 8*512
Boot image size = 311474488 (0x1290b938) bytes
Missing or illegal ip address for variable DEFAULT_GATEWAYSlave C2W Master:2 Write failure!
SXHHoldMaster (offset:0x0000000C) = 0x00000011
get_mac_addr: Couldn't find a valid macaddr
Missing or illegal ip address for variable IP_ADDRESS
Missing or illegal ip address for variable IP_SUBNET_MASK
Package header rev 0 structure detected
Calculating SHA-1 hash...done
validate_package: SHA-1 hash:
calculated 2affd481:186e5415:80bfc70b:86044485:867b3c1d
expected 2affd481:186e5415:80bfc70b:86044485:867b3c1d
Image validated
%IOSXEBOOT-4-BOOT_SRC: (rp/0): Non-HD Boot
03/07 01:51:57.631: %CMRP-3-IDPROM_ACCESS: Failed to access or process IDPROM 'midplane': Invalid argument -Traceback= 1#3062921b41df6c7cc68a48d54ceee889 errmsg:ECA1000+2160 :10000000+2C414 :10000000+4BD84 :10000000+38E00 :10000000+3A4AC c:E421000+1E938 c:E421000+1EAE0 Mar 7 01:51:58.399 R0/0: %BOOT-0-APP_STARTFAILCRIT: Failed to launch a critical process cman
System Bootstrap, Version 12.2(33r)XNC, RELEASE SOFTWARE (fc1)
Copyright (c) 2009 by cisco Systems, Inc.
Last reset cause: LocalSoft
Last reset at: Wed Mar 07 01:52:18 UTC 2012
Image validated
03/07 01:53:56.654: %CMRP-3-IDPROM_ACCESS: Failed to access or process IDPROM 'midplane': Invalid argument -Traceback= 1#3062921b41df6c7cc68a48d54ceee889 errmsg:ECA1000+2160 :10000000+2C414 :10000000+4BD84 :10000000+38E00 :10000000+3A4AC c:E421000+1E938 c:E421000+1EAE0 Mar 7 01:53:57.423 R0/0: %BOOT-0-APP_STARTFAILCRIT: Failed to launch a critical process cman
Last reset at: Wed Mar 07 01:54:17 UTC 2012
Image validated
03-08-2012 01:58 AM
any suggestion?
03-09-2012 03:47 AM
I am very much afraid that without the help of Cisco TAC, this issue can not be solved. It is quite probable that there is a hardware defect or malfunction, and the device should be replaced. You could theoretically try to dismantle and reseat all modular components in your router, including checking for ICs and their proper seating in their sockets (if there are any), but beyond this - I don't think anyone can help.
I apologize for not being able to help you more.
Best regards,
Peter
03-09-2012 02:21 PM
Kinda agree with Peter.
However, can you re-seat the RP module and try again?
03-09-2012 05:11 PM
Thanks Peter and Leolaohoo. We pull up all modules and test on another ASR1002 and all can bootup. So it may the chassis broken. We have to claim RMA..... Anyway thanks your great help.
