asr1004 for nat
julxu
I have ASR1004, and it will be border router, I want put nat for subnet 10.0.0.0/12 on it, current the box has only one link to it has no big load. if I add nat on, please advice, does it possible cause load problem? or other problems?
Another basic question, just want confirm, I want nat 10.0.0.0/12 to one ip address, is it ok? and the 10.0.0.0/12 will includes subnets 10.0.?.0/24, if so, how can I trace all the histories, just log to local server? please advice.
Any comments will be appreciated
Thanks in advance
Julxu
2 Accepted Solutions
Lei Tian
The performance is based on the ESP. ESP 2.5 is the lowest can give you 2.5 Gbps NAT throughput.
You can config NAT /12 to one IP. As long as you don't have 60k concurrent sessions, it will be fine.
HTH,
Lei Tian
Hi Julxu,
The NAT throughput is 20G for ESP20. Yes, if you have more sessions, you need more IP.
HTH,
Lei Tian
Lei Tian
HTH,
Lei Tian
Lei
Thanks for reply.
I have module AS1000-ESP20, and ios version 15.3(3)S, I guess it is ok.
you said, I can nat subnet /12  to one ip, as long as concurrent sessions less than 60K. can I understand it as if I have more than that amount, I still can use nat, just give more than one ip address, am I right?
Please advice
Julxu
Hi Julxu,
HTH,
Lei Tian
