ASR1006 - bootflash: not present
johnelliot6
Level 2
Level 2
Hi Guys,
Have an ASR1006 (Dual RP's/Dual ESP's), and the "standby" RP is stuck in rommon:
System Bootstrap, Version 12.2(33r)XN2, RELEASE SOFTWARE (fc1)
Copyright (c) 2008 by cisco Systems, Inc.
Current image running: Boot ROM0
Last reset cause: LocalSoft
ASR1000-RP1 platform with 4194303 Kbytes of main memory
no valid BOOT image found
Final autoboot attempt from default boot device...
media drive bootflash: not present
boot: cannot determine first file name on device "bootflash:"
autoboot: boot failed, restarting...
Then checking dev, bootflash is there, but then cant be read:
rommon 1 > dev
Devices in device table:
        id  name
bootflash:  Internal flash drive
harddisk:  Internal hard disk
     usb0:  External USB drive 0
     usb1:  External USB drive 1
rommon 2 > dir bootflash:
Any suggestions greatly appreciated.
7 Replies 7
cedar_lee
In my case, after cold reboot, issue no more.
It happened to us with a C9300 stack. I performed a cold reboot too, I disconnected all of them from the power supply and connected them again.
After that everything was well. We're trying to figure out what happened.
Some of the errors we got:
switch: dev
id name
tftp: network via tftp
usbflash0: External USB drive 0
usbflash1: External USB drive 1
switch:
switch:
switch: dir flash:
media drive flash: not present.
Last reset cause: SoftwareReload
C9300-48U platform with 8388608 Kbytes of main memory
media drive sda8: not present.
attempting to boot from [flash:packages.conf]
ERROR: failed to boot from flash:packages.conf (Not Found)
Please wait while the system restarts.
Initializing Hardware...
You are my hero!
Hani Elgaali
Hi, Im also having the same issue, here is my out boot after resetting from rommon:
Current image running: Boot ROM1
Last reset at: Wed Jan 28 17:01:05 UTC 2015
boot: error executing "boot bootflash:asr1000rp1-adventerprisek9.03.07.00.S.152-4.S.bin"
System Bootstrap, Version 15.2(1r)S, RELEASE SOFTWARE (fc1)
Copyright (c) 2011 by cisco Systems, Inc.
Last reset at: Wed Jan 28 17:02:05 UTC 2015
If anyone has a solution to this please respond.
Hani
Hani,
You can boot the ASR's IOS straight from a USB stick.
Thanks Leo, Can the ASR rp1 from the HDD, I'm not sure if that a valid option.
Thanks again,
Hani
Not HDD, a USB thumb drive.
