10-25-2013 03:53 PM - edited 03-04-2019 09:25 PM
ASR1006# upgrade rom-monitor filename bootflash:asr1000-rommon.153-3r.S1.pkg all
Upgrade rom-monitor on Route-Processor 0
Target copying rom-monitor image file
rsync: link_stat "rommon/mcp/RP/RP2/latest.bin" (in rommon_upgrade_pub) failed: No such file or directory (2)
rsync error: some files could not be transferred (code 23) at /auto/mcpbuilds13/release/03.07.03.S/BLD-03.07.03.S/contrib/rsync/main.c(1392) [receiver=2.6.9]
ASR1006#show platform
Chassis type: ASR1006
Slot Type State Insert time (ago)
0 ASR1000-SIP10 ok 00:11:22
0/2 SPA-5X1GE-V2 ok 00:10:14
2 ASR1000-SIP10 ok 00:11:22
R0 ASR1000-RP2 ok, active 00:11:22
P0 ASR1006-PWR-AC ok 00:11:05
P1 ASR1006-PWR-AC ok 00:11:04
Slot CPLD Version Firmware Version
0 09111601 12.2(33r)XNC
2 09111601 12.2(33r)XNC
R0 10021901 15.3(1r)S
ASR1006 with RP2, running asr1000rp2-adventerprisek9.03.07.03.S.152-4.S3.bin
10-25-2013 04:38 PM
Means the bootstrap file is not found in the place you've specified, i. e. the bootflash.
Can you please post the output to the command "dir"?
10-25-2013 04:41 PM
ASR1006#dir
Directory of bootflash:/
11 drwx 16384 Nov 25 2010 03:15:16 +00:00 lost+found
193537 drwx 4096 Nov 5 2012 02:14:00 +00:00 vman_fdb
129025 drwx 4096 Nov 25 2010 03:18:18 +00:00 .installer
48385 drwx 4096 Aug 27 2013 23:39:52 +00:00 .prst_sync
64513 drwx 4096 Nov 25 2010 03:47:43 +00:00 .rollback_timer
14 -rw- 2361648 Mar 14 2013 15:28:21 +00:00 asr1000-rommon.153-1r.S.pkg
48386 -rw- 598912444 Aug 27 2013 01:48:16 +00:00 asr1000rp2-adventerprisek9.03.09.00.S.153-2.S.bin
12 -rw- 569597380 Oct 9 2013 13:23:38 +00:00 asr1000rp2-adventerprisek9.03.10.00.S.153-3.S-ext.bin
13 -rw- 15261696 Oct 9 2013 13:25:35 +00:00 asa824-11-k8.bin
209667 -rw- 7745 Aug 23 2013 23:22:13 +00:00 packages.conf
15 -rw- 555312 Oct 25 2013 22:14:35 +00:00 asr1000-rommon.153-3r.S1.pkg
16 -rw- 484677032 Oct 25 2013 22:36:09 +00:00 asr1000rp2-adventerprisek9.03.07.03.S.152-4.S3.bin
The error pops up when I try to upgrade rommon
10-25-2013 04:53 PM
I know what is going on ...
Your file is "corrupt" or download was not completed. Look at the file size. It doesn't add up.
Do this command "verify /md5 bootflash:asr1000-rommon.153-3r.S1.pkg 7d7b3342b4922b7216ceea8bf112caf4" and I can assure you this will kick up an error message.
"7d7b3342b4922b7216ceea8bf112caf4" is the MD5 hash value taken from the Cisco website. Besides, look at the file size listed in the Cisco website. The file is suppose to be "2.42 MB".
10-25-2013 07:02 PM
ASR1006#verify /md5 bootflash:
bootflash:asr1000-rommon.153-3r.S1.pkg c818ccd5af831f844646a74ffe33d1d8
........................................................................................................................................Done!
Verified (bootflash:asr1000-rommon.153-3r.S1.pkg) = c818ccd5af831f844646a74ffe33d1d8
MD5 is actually correct.
ASR1000 Series ROM Monitor upgrade package for Gigabit Ethernet Linecard
ASR1000 Series ROM Monitor upgrade package for m8500 and x86
asr1000-rommon.152-4r.S1.fc1.pkg
Confused. What is the rommon upgrade for?
10-25-2013 07:27 PM
Resolved Caveats in ROMmon Release 15.3(3r)S1
The following issue has been resolved in Release 15.3(3r)S1:
Modified the CPLD's HKP PLL configuration register value in the Cisco ASR 1000 Ethernet Line Card to reflect IBM's recommended value for the correct HKP PLL configuration.
Check out the bug. If you have the line card affected, then upgrade to 15.3(3r)S1. Otherwise, don't worry about it.
The second software is an older ROMmon.
06-29-2014 01:52 PM
Try transfer the file in ftp binary mode rather than ascii mode
08-16-2019 03:54 AM - edited 08-16-2019 03:59 AM
I have a similar problem.
I have some ASR1006 chassis with 2x RP2, 2x ESP40 and 2x SIP40 (2x SPA-10G cards in the SIPs).
During the migration I completely followed the official Cisco instructions: https://www.cisco.com/c/en/us/td/docs/routers/asr1000/release/notes/xe-16-9/asr1000-rel-notes-xe-16-9.html#concept_zdm_2nx_5bb
Especially regarding the recommended ROMMON versions:
| Cisco IOS XE Release | ASR 1000 RP2 | ASR 1000-SIP40 | ASR 1000-ESP40 |
| 16.9.x | 16.9(5r) | 16.3(2r) | 16.3(2r) |
All RPs run on IOS XE 16.9.3 and ROMMON Verion 16.9(5r).
All SIP40s run on ROMMON version 16.3(2r).
Only a few (not all) ESP40 can not be upgraded to 16.3(2r).
The following error message appears:
Target copying rom-monitor image file cp: omitting directory '/' md5sum: /: Is a directory md5sum: /bootflash/EFI/UpdateCapsule/UpdateCapsuleFile.bin: No such file or directory
Does anyone have any idea where the problem is or how to solve it?
Below you can see the whole CLI output:
Router# sh ver Cisco IOS XE Software, Version 16.09.03 Cisco IOS Software [Fuji], ASR1000 Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 16.9.3, RELEASE SOFTWARE (fc2) Technical Support: http://www.cisco.com/techsupport Copyright (c) 1986-2019 by Cisco Systems, Inc. Compiled Wed 20-Mar-19 08:02 by mcpre Router# sh platform Chassis type: ASR1006 Slot Type State Insert time (ago) --------- ------------------- --------------------- ----------------- 0 ASR1000-SIP40 ok 00:04:27 0/0 SPA-1X10GE-L-V2 ok 00:03:05 0/2 SPA-1X10GE-L-V2 ok 00:02:57 1 ASR1000-SIP40 ok 00:04:27 1/0 SPA-1X10GE-L-V2 ok 00:03:05 1/2 SPA-1X10GE-L-V2 ok 00:02:53 R0 ASR1000-RP2 ok, active 00:04:27 R1 ASR1000-RP2 ok, standby 00:04:27 F0 ASR1000-ESP40 ok, active 00:04:27 F1 ASR1000-ESP40 ok, standby 00:04:27 P0 ASR1006-PWR-AC ok 00:03:56 P1 ASR1006-PWR-AC ok 00:03:55 Slot CPLD Version Firmware Version --------- ------------------- --------------------------------------- 0 00200800 16.3(2r) 1 00200800 16.3(2r) R0 10021901 16.9(5r) R1 10021901 16.9(5r) F0 1003190E 16.2(1r) F1 1003190E 15.3(3r)S
Thanks!
