Ping Drop
Yasmeen
Hi Team
          I am getting ping drop on ipv6,
Switch#ping 2001:4860:4860::8888 source vlan 190
Sending 5, 100-byte ICMP Echos to 2001:4860:4860::8888, timeout is 2 seconds:
Packet sent with a source address of 2001:100:0:190::4
!UU!U
Success rate is 40 percent (2/5), round-trip min/avg/max = 10/10/10 ms
can u suggest solution for this
Giuseppe Larosa
Hello Yasmeen,
the U ICMP code should mean unreachable for example administratively forbidden for example by an ACL.
U: A destination unreachable error PDU was received
see for ICMPv6 the following document
https://www.cisco.com/c/en/us/support/docs/ip/routing-information-protocol-rip/22974-icmpv6codes.html#errors
and for ICMP codes and traceroute operations in IPv4
https://www.cisco.com/c/en/us/support/docs/ios-nx-os-software/ios-software-releases-121-mainline/12778-ping-traceroute.html
Verify how many paths to the destination address 2001:4860:4860::8888 exists on the local router.
using show ipv6 route 2001:4860:4860::8888
Hope to help
Giuseppe
Giuseppe Larosa
Hello Yasmeen,
Hope to help
Giuseppe
Yasmeen
HI Guipse,
Switch#traceroute ipv6 2001:4860:4860::8888
Tracing the route to 2001:4860:4860::8888
1 2001:100:0:193::1 !U *
2001:100:0:191::1 !U
Hello Yasmeen,
if this is a lab can you provide a network diagram and configuration of involved network devices ?
Hope to help
Giuseppe
