ASR1006 ISSU upgrade fail‏
johnelliot6
Level 2
Level 2
Hi Guys,
ASR1006 dual RP/Dual ESP - Followed this guide: http://www.cisco.com/en/US/docs/routers/asr1000/configuration/guide/chassis/issu.html (Using ISSU to Perform a Consolidated Package Upgrade in a Dual Route Processor Configuration)
Current XE version: asr1000rp1-adventerprisek9.02.01.01.122-33.XNA1 and upgrading to: asr1000rp1-adventerprisek9.03.05.02.S.152-1.S2
I got to step 5 (issu load version rp 1 file stby-bootflash:asr1000rp1-adventerprisek9.03.05.02.S.152-1.S2.bin), but received the following error:
*May
2 18:01:50.246: %ASR1000_SPA-3-INVALID_SLOT_NUM: slot= 15, max slot = 14
-Traceback= 1#3c0e9c526e153a8453b1a7f7d5b8cf1f :10000000+61C3B8 :10000000+61A51C
:10000000+61A8A0 :10000000+25D7028 :10000000+2433E5C :10000000+2433E98
iosd_unix:C25F000+13F60 iosd_unix:C25F000+11690 pthread:BF56000+5DA0
*May 2 18:01:50.248: %ASR1000_SPA-3-INVALID_SUBSLOT_NUM: subslot= 15, max
subslot = 4
:10000000+61A51C :10000000+61A8A0 :10000000+25D7030 :10000000+2433E5C
:10000000+2433E98 iosd_unix:C25F000+13F60 iosd_unix:C25F000+11690
And the standby RP just continues to reload (loop), and the above error is printed, then reloads again
Further reading of the ISSU guide, looks like upgrading from 2.x train to 3.x train is unsupported....bugger!
So 2 questions:
How do I now stop the standby RP from looping?
And then to upgrade, I would need to copy the new IOS to both bootflash, and follow this guide:
http://www.cisco.com/en/US/docs/routers/asr1000/configuration/guide/chassis/Package_Management.htm
"Managing and Configuring a Consolidated Package Using the copy Command"
Any suggestions are greatly appreciated.
0 Replies 0
