ASR1006 MAC Addresses on ARP Table are not in Bridge-Domain MAC List
bandararmc
I am trying to trace a IP/MAC address.
I can see this mac address is receiving for a BDI (100).
XXXX#show arp 192.168.100.1
Protocol Address Age (min) Hardware Addr Type Interface
Internet 192.168.100.1 6 aaaa.bbbb.cccc ARPA BDI100
This BDI is configured on several interfaces.
So I tried to check "show bridge-domain 100" to find out the exact interface receiving this mac. But this mac is not an output for BDI 100.
XXXX#show bridge-domain 100 | in AAAA:BBBB:CCCC
(empty)
Please help if any of you have an idea about this  output.
Thank you
6 Replies 6
hard to say, maybe this is a secured MAC address. Does anything show up with:
--> show bridge-domain 100 mac security address
Also, the IP address 192.168.100.1, is that the default gateway for a subnet ? What device does this IP address belong to ?
Hello Georg,
Thank for your reply.
Security MAC is not configured here.
CORE1#show bridge-domain 100 mac security address
% Invalid input detected at '^' marker.
192.168.100.1 is not  the gateway for BDI 100. I am actually trying to trace the device. This issue is not only for this IP.
show arp bdi 100 ---> 224 MAC/IP addresses
show bridge-domain 100 --> only 64 MAC output
I just want to trace some IPs destination/device using the receiving interfaces. But here I can not find the source interface for these IPs.
Thank you
Hello
Perform the following on the core switches then downstream towards the source
show mac-address address AAAA:BBBB:CCCC
Kind Regards
Paul
Hello Pual,
Thank you for the reply.
This network is a complex one. there are few of switches and some servers connected this router.
I tried few switches and for those switches, the source is coming from this router.
Is their any way to find the source interface directly from this router?
Thank you..
mlund
Level 7
Level 7
The mac address table has a timeout of 5 minutes, but the arp table has a timeout of hours. So try to first ping the address, then check the mac address table.
/Mikael
Hi Mikael,
Thank you for your reply.
I did the ping first. But still I could not find the that mac address on " show bridge-domain bdi 100" output.
Thank you
