Cisco 887va router configuration
shaun.lang
Hi, I was wondering if anyone has manged to configure a cisco 887va router with layer 2 ports for CCNA project where I'm trying to get a internet connection from my home router. My home router is 4G router which does support bridge mode and the IOS version I'm using is 15.4. I've configured Vlan interface to take the layer 3 info and while my 887va router can ping 8.8.8.8 successfully, my pc can ping both interface of the cisco router but it can't ping my 4G router.  I'd appreciate any help given.
My config file is below
Current configuration : 1849 bytes
! Last configuration change at 10:38:11 UTC Tue Dec 7 2021
version 15.4
hostname Lang-R
boot-start-marker
boot-end-marker
aqm-register-fnf
no aaa new-model
memory-size iomem 10
ip dhcp pool Lang
 network 192.168.10.0 255.255.255.0
 default-router 192.168.8.1
 dns-server 8.8.8.8 4.4.4.4
ip cef
no ipv6 cef
license udi pid C887VA-K9 sn FCZ182692E1
controller VDSL 0
interface ATM0
 no ip address
 shutdown
 no atm ilmi-keepalive
interface Ethernet0
 no ip address
 shutdown
interface FastEthernet0
 description HDCPRouter
 switchport access vlan 25
 no ip address
interface FastEthernet1
 no ip address
 shutdown
interface FastEthernet2
 no ip address
 shutdown
interface FastEthernet3
 description SwitchLAN
 switchport access vlan 26
 no ip address
interface Vlan1
 no ip address
interface Vlan25
 ip address dhcp
 ip nat outside
 ip virtual-reassembly in
interface Vlan26
 ip address 192.168.10.1 255.255.255.0
 ip nat inside
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface FastEthernet0 overload
ip nat inside source static 192.168.10.3 192.168.10.254
ip route 0.0.0.0 0.0.0.0 192.168.8.1
access-list 1 permit any
access-list 1 permit 192.168.10.0 0.0.0.255
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
 no modem enable
line aux 0
line vty 0 4
 login
 transport input none
scheduler allocate 20000 1000
end
I don't understand your topology to be honest. What is the inside network, and what the outside ? 192.168.8.0/24 is Vlan 25 ?
Try and make the changes marked in bold:
version 15.4
hostname Lang-R
boot-start-marker
boot-end-marker
aqm-register-fnf
no aaa new-model
ip dhcp pool Lang
--> default-router 192.168.10.1
ip cef
no ipv6 cef
controller VDSL 0
interface ATM0
no ip address
shutdown
interface Ethernet0
no ip address
shutdown
no ip address
no ip address
shutdown
no ip address
shutdown
no ip address
interface Vlan1
no ip address
interface Vlan25
ip address dhcp
ip nat outside
interface Vlan26
ip nat inside
no ip http server
--> ip nat inside source list 1 interface Vlan 25 overload
--> no ip nat inside source static 192.168.10.3 192.168.10.254
--> ip route 0.0.0.0 0.0.0.0 Vlan 25
--> no access-list 1 permit any
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
login
end
Hi Georg,
My topology is ISP router / outside is 192.168.8.0/24 and the pc or switch is inside 192.168.10.0/24. I'll try your suggestion and let you know what happens, thanks.
Shaun
