ASR1006-X: Enable password removed. Cannot SSH to remote router
The enable and secret password was removed from my router remotely and now I cannot enter enable mode for the router from a SSH session.  Is there a way to reenable the enable password remotely?  I can log into the router I just cannot enter the priv exec mode to enter command and receive "% Error in authentication". My device is across the country so I do not have the ability to console in.
6 Replies 6
balaji.bandi
you need go password recovery physically (no remote option)  - you may need some one to go onsite and use Teams to give console access.
https://www.cisco.com/c/en/us/td/docs/routers/asr1000/install/guide/asr1routers/asr-1000-series-hig/asr-hig-tbl.html#task_1043898
BB
Leo Laohoo
Console or use SNMP to inject the command back into the router.
@Leo Laohoo Interesting suggestion. I remember using:
snmpset -v:2c -c <community_string> <router_IP> <OID> s "NEW_PASSWORD"
to do this, but the problem was to find the right OID. Maybe an snmpwalk:
snmpwalk -v2c -c <community_string> <router_IP> <MIB_tree>
can reveal that ?
johnlloyd_13
Level 9
Level 9
hi,
with such a big router, you should have AAA in place.
as others suggested, try to physically console and hopefully you can directly login to privilege exec mode.
if no luck, then you'll have to perform a router password recovery.
then deal with who removed the PW later on and change it to avoid being compromised.
Another 'option' would be to ask someone to turn off the power and turn it back on. Maybe you are lucky and the changes (password removal) were not saved to memory, and the router boots with the original config...
sitecountryy
Without physical access to the router, it's not possible to reconfigure the enable password remotely. You’ll need someone at the location to console in and restore it, or use an out-of-band management tool if available. Ensure backups and alternate admin accounts are set up for future prevention.
