ASR1009-X 40gig Ethernet
vmiragli
Can someone tell me what SIP/SPA/EPA/whatever is needed to connect an ASR1009-X using 40-gig Ethernet?  Thanks.
@vmiragli wrote:
So I need a ASR1000-SIP40, then I can put one or two EPA-CPAK-2X40GE into that?
Correct.  The SPA slides into the SIP and the SIP slides into the chassis.
I think this is what you need:
Cisco ASR 1000 2x40GE Ethernet Port Adapter (breakout cable)
EPA-CPAK-2X40GE
Cisco ASR 1000 Series Ethernet Line Cards Data Sheet
https://www.cisco.com/c/en/us/products/collateral/application-networking-services/wide-area-application-services-waas-software/data-sheet-c78-729778.html
Leo Laohoo
You'll also need a SIP tray.
Thanks all.
What is meant by "breakout cable"?  Is that a separate component?
