ASR1013 Fabric Capacity Question
Peyman Zadmehr
Researching about ASR1013 I have some Questions:
1- If we install ESP200 + 4xSIP40 then what will be the bandwidth per slot and Capacity of Inter-slot Fabric?
2- Does ESP200 provides the Fabric Bandwidth in this router?
3- Regarding Question#1, Will we have 40GE per-slot in line-rate?
4- Again regarding Qesution#1, Will we have 40Gbps capacity in Fabric Between each Slot
5- Is the values in Full-Duplex mode or Half-Duplex?
Thank you for your help and support
Peyman
marce1000
 - Some answers may be found in the datasheet : https://www.cisco.com/c/en/us/products/routers/asr-1013-router/index.html  - But before any engaged business efforts also take care of the EOL-notice :
             https://www.cisco.com/c/en/us/products/collateral/routers/asr-1000-series-aggregation-services-routers/eos-eol-notice-c51-744362.html?dtid=osscdc000283
 M.
marce1000
 M.
Thank you for update. I checked the Cisco Live! presentation and I found my Answers
Best Regards
Peyman
