11-05-2014 04:34 PM - edited 03-05-2019 12:06 AM
Dear all,
Anyone know is ASR9000 series router supported DMVPN setup? I had browse through the Cisco link and can't found the DMVPN configuration guide for ASR9000 series. Pls help me if you know the answer or link me to the related URL, Thanks a lot.
Chong
Solved! Go to Solution.
11-25-2014 12:23 AM
Hello Chong,
Trust you are doing great.
DMVPN is not supported on ASR.
Please refer the below link for the supported platforms for DMVPN
http://www.cisco.com/c/en/us/products/collateral/security/dynamic-multipoint-vpn-dmvpn/data_sheet_c78-468520.html
Mohit
** Please rate if you find this post helpfull
11-25-2014 12:23 AM
Hello Chong,
Mohit
11-25-2014 12:54 AM
Typo error
DMVPN is not supported on ASR9000
01-11-2015 07:52 PM
Thanks for the confirmation, appreciated.
