ASR9001 IOS-XR: show memory vs. SNMP processor memory query
Frank-M
I have a few ASR-9001-RPs, IOS-XR (6.2.3) with 8GB of memory installed.
"Show mem" looks good - at about 50%
#show memory summary
Wed Feb 13 06:50:11.483 EST
Physical Memory: 8192M total (4628M available)
 Application Memory : 7994M (4628M available)
 Image: 69M (bootram: 69M)
 Reserved: 128M, IOMem: 0, flashfsys: 0
 Total shared window: 177M
Our monitoring system (Solarwind's N-Able) monitors these routers with the ciscoMemoryPoolUsed/Free OIDs and that results in these values, showing a utilization of >85% (commas inserted to make numbers readable)
snmpget <options> <ip> .1.3.6.1.4.1.9.9.48.1.1.1.2.1
iso.3.6.1.4.1.9.9.48.1.1.1.2.1 = STRING: "processor"
snmpget <options> <ip> .1.3.6.1.4.1.9.9.48.1.1.1.5.1
iso.3.6.1.4.1.9.9.48.1.1.1.5.1 = Gauge32: 3,527,686,248
snmpget <options> <ip> .1.3.6.1.4.1.9.9.48.1.1.1.6.1
iso.3.6.1.4.1.9.9.48.1.1.1.6.1 = Gauge32: 559,738,880
Am I monitoring the wrong OID? Does that OID mean something else than the "show mem" output? Is there a CLI command that would show the same values as the SNMP-OID query?
I'm obviously missing something here, can someone shed light?
    Frank
i.voevodin
It's look like root cause of issue it is that counter is Gauge32
"This means that it can represent a non-negative integer that can increase or decrease, but it cannot exceed a maximum value. This value cannot be greater than 232-1 (4294967295 decimal), and the minimum value cannot be smaller than 0 (RFC2578). Therefore, this represent a problem when the memory usage exceed 4GB."
SolarWind explain that problem here: https://thwack.solarwinds.com/product-forums/network-performance-monitor-npm/f/forum/42620/memory-and-cpu-utilization-per-board-cisco-asr9000-ios-xr
