not learning mac issue
I have this issue with MAC it is own device
when I run show arp for int Te0/1/0/16/2.3038
result no info
when I run show run in Te0/1/0/16/2.3038
description Connection to *************************
ipv4 address ********************************
ipv6 address **************************
load-interval 30
encapsulation dot1q 3038
it means the config there but not learning its own mac
what is the issue here ?
8 Replies 8
balaji.bandi
what model of the device and IOS code running ?
Looks like this sub-interface - is this interface up ?
show in Te0/1/0/16/2.3038  (what is the output ?)
are you able to ping locally ipv4 address ?
BB
the other site on this  interface is not reachable
NCS-5500   Cisco IOS XR Software, Version 7.8.1
Last link flapped 2w6d
ARP type ARPA, ARP timeout 04:00:00
Last input 00:00:00, output 00:00:00
30 second input rate 0 bits/sec, 0 packets/sec
30 second output rate 0 bits/sec, 0 packets/sec
1848 packets input, 181112 bytes, 0 total input drops
0 drops for unrecognized upper-level protocol
Received 0 broadcast packets, 353 multicast packets
44819 packets output, 4109790 bytes, 0 total output drops
Output 0 broadcast packets, 8953 multicast packets
need more information ? how is other side connected ?
Are you able to ping the IPv4 address locally ?
do you have any other sub-interface which is working ?
BB
TenGigE0/1/0/16/2.3038 is up, line protocol is up
yeah I was able to ping my IPv address shown on int Te0/1/0/16/2.3038
I meant this Te0/1/0/16/2.3038  is an PE router in Datacente and conncted to cell site and cell site is not reachable
you need start troubleshooting - is the other end device up ? what is the status of far end interface ?
BB
I just figure it out the This site has duplicate config on two different NNI ports and ty all
Glad all good and you able to figure out the issue.
BB
