Understanding the default route and static route across multiple paths
goyourmin
hello!
I'm sorry. I feel like I've asked you this question many times.
I'm going to ask you exactly what I don't understand.
This configuration is only static. (In reality, due to the use of VPNs, firewalls, etc., dynamic is not possible.)
- Is it possible to set it in multiple paths from the
default route
Q1. Is it possible to set the
default route
direction from the PC host to the ISP in only one direction? Why?
Q2. Is it possible to use the AD or metric config between interlinks as a backup route for the
default route
ex) L3-Switch-1 <-> L3-Switch-2(interlink), L3-Switch-3 <-> L3-Switch-4(interlink), L3-Switch-5 <-> L3-Switch-6(interlink)
Q3. In the case of
L3-Switch-1,2
attached to the ISP, why do I need to set the interlink static as well as the
default route
Q4. On the other hand, why does
L3-Switch-3,4,5,6
not include static for the upper band and only static for the lower band?
config)
There are too many static settings, so I changed it easily.
ISP
router bgp 1
bgp router-id 1.1.1.1
bgp log-neighbor-changes
network 1.1.1.1 mask 255.255.255.255
neighbor 100.100.100.2 remote-as 2
neighbor 100.100.100.6 remote-as 2
maximum-paths 2
L3-Switch-1
router bgp 2
bgp router-id 2.2.2.2
network 2.2.2.2 mask 255.255.255.255
redistribute static
neighbor 172.16.0.2 remote-as 2
neighbor 172.16.0.2 update-source Loopback0
neighbor 172.16.0.2 next-hop-self
neighbor 100.100.100.1 remote-as 1
ip route 0.0.0.0 0.0.0.0 Ethernet0/3 100.100.100.1 name ISP
ip route 0.0.0.0 0.0.0.0 Ethernet0/0 172.16.0.2 100 name interlink
ip route 10.0.0.0 255.0.0.0 Ethernet0/1 172.16.1.2 name PC-host-lo0
ip route 10.0.0.0 255.0.0.0 Ethernet0/0 172.16.0.2 100 name PC-host-interlink
ip route 172.16.0.0 255.255.0.0 Ethernet0/1 172.16.1.2 name L3-link
ip route 172.16.0.0 255.255.0.0 Ethernet0/0 172.16.0.2 100 name L3-link
L3-Switch-2
router bgp 2
bgp router-id 3.3.3.3
network 3.3.3.3 mask 255.255.255.255
redistribute static
neighbor 172.16.0.1 remote-as 2
neighbor 172.16.0.1 update-source Loopback0
neighbor 172.16.0.1 next-hop-self
neighbor 100.100.100.5 remote-as 1
ip route 0.0.0.0 0.0.0.0 Ethernet0/3 100.100.100.5 name ISP
ip route 0.0.0.0 0.0.0.0 Ethernet0/0 172.16.0.1 100 name interlink
ip route 10.0.0.0 255.0.0.0 Ethernet0/1 172.16.2.2 name PC-host-lo0
ip route 10.0.0.0 255.0.0.0 Ethernet0/0 172.16.0.1 100 name PC-host-interlink
ip route 172.16.0.0 255.255.0.0 Ethernet0/1 172.16.2.2 name L3-link
ip route 172.16.0.0 255.255.0.0 Ethernet0/0 172.16.0.1 100 name L3-link
L3-Switch-3
ip route 0.0.0.0 0.0.0.0 Ethernet0/1 172.16.1.1 name L3-1
ip route 0.0.0.0 0.0.0.0 Ethernet0/0 172.16.5.2 100 name interlink
ip route 10.0.0.0 255.0.0.0 Ethernet0/2 172.16.3.2 name PC-host-lo0
ip route 10.0.0.0 255.0.0.0 Ethernet0/0 172.16.5.2 100 name PC-host-interlink
ip route 172.16.0.0 255.255.0.0 Ethernet0/2 172.16.3.2 name L3-link
ip route 172.16.0.0 255.255.0.0 Ethernet0/0 172.16.5.2 100 name L3-link
L3-Switch-4
ip route 0.0.0.0 0.0.0.0 Ethernet0/1 172.16.2.1 name L3-2
ip route 0.0.0.0 0.0.0.0 Ethernet0/0 172.16.5.1 100 name interlink
ip route 10.0.0.0 255.0.0.0 Ethernet0/2 172.16.4.2 name PC-host-lo0
ip route 172.16.0.0 255.255.0.0 Ethernet0/2 172.16.4.2 name L3-link
L3-Switch-5
interface vlan 10
ip address 10.10.10.2 255.255.255.0
standby 10 ip 10.10.10.1
standby 10 priority 110
standby 10 preempt
standby 10 track 10 decrement 20
track 10 interface Ethernet0/2 line-protocol
ip route 0.0.0.0 0.0.0.0 Ethernet0/2 172.16.3.1 name L3-3
ip route 0.0.0.0 0.0.0.0 172.16.4.2 100 name interlink
L3-Switch-6
interface vlan 10
ip address 10.10.10.3 255.255.255.0
standby 10 preempt
ip route 0.0.0.0 0.0.0.0 Ethernet0/2 172.16.4.1 name L3-4
ip route 0.0.0.0 0.0.0.0 172.16.3.2 100 name interlink
Best regards,
2 Accepted Solutions
Giuseppe Larosa
Hello @goyourmin ,
I remember the previous thread.
default route
the PC host can set its
default gateway
to the HSRP / VRRP VIP and it will send traffic to the active router in the HSRP / VRRP group. This is the common choice it provides redundancy with the host that needs only a
default gateway
and it is not aware of current routing setup and topology.
default route
ex)
Yes if using floating static routes with an AD value the backup default static routes are used only if primary route fails.
I see you have configured in this way
and with the same logic everywhere. it looks like fine.
>> Q3. In the case of
L3-Switch-1,2
default route
For the fact no dynamic routing is used downstream devices
L3-switch3 and L3-switch4
cannot detect if the eBGP session between
L3Switch1 and ISP router, and between L3 switch2 and ISP router
are up and running or not.
To be noted for
L3switch1 and L3switch2
you can use an IBGP session between them instead of a backup static route as I have explained in the previous thread.
I would suggest to use an iBGP session and to use neigh
100.100.100.1 weight 500
the iBGP session would act as a backup path and it is dynamic.
L3-Switch-3,4,5,6
Because for going "upstairs " is enough to use the
default route
without providing details of all inter switch link IP subnets.
Final note:
as I have noted in previous thread the ISP router should inject a
default route
into BGP this is what happens in real world, there s no sense in having an eBGP session and not receiving the
default route
on it.
For a lab is enough the following:
Router ISP
ip route 0.0.0.0 0.0.0.0 null0 200
router bgp 1
network 0.0.0.0
This makes a great difference as you can use an iBGP session between
L3switch1 and L3switch2 on link 172.16.0.1 / 172.16.0.2
and each device can detect if there is a
default route
available in BGP with preference given to the eBGP route.
Without injecting a
default route
in eBGP from ISP router if both ISP links are down you would have a routing loop on interlink switch .
Hope to help
Giuseppe
Hello @goyourmin ,
- If
L3-Switch-3 config the default route
in both directions, will the traffic become disoriented and cause a loop?
(L3-Switch-3 default route -> L3-Switch-1 , L3-Switch-3 default route -> L3-Switch-5
This is really dangerous
L3switch-3 should point to L3-switch1
only, because as I have explained in your previous thread each node when having multiple
of same AD would install both in routing table and it would use a locally seed to make a load balancing decision
So a specific flow could be routed by
L3-Switch5 to L3Switch3 and L3switch3
could send it back to
L3switch5
just using its own CEF load balancing decision and this is a routing loop even with no faults in the network.
L3Switch3
could have two
default routes
in a safe way only if
L3Switch3
would have a direct link to both
L3Switch1 and to L3switch2
in that case you could use two
default routes
pointing to the upper multilayer switches.
Hope to help
Giuseppe
Giuseppe Larosa
Hello @goyourmin ,
default route
default gateway
default gateway
default route
ex)
>> Q3. In the case of
L3-Switch-1,2
default route
To be noted for
L3-Switch-3,4,5,6
default route
Final note:
default route
default route
on it.
Router ISP
router bgp 1
network 0.0.0.0
default route
Without injecting a
default route
Hope to help
Giuseppe
It's such a pleasure to see you again.
Question Q1 seems to have been mistranslated in translation, so I will ask again.
Q. I'd like to know why I need to set the
default route
in only one direction.
ex)
 PC -> L3-Switch-5 -> L3-Switch-3 -> L3-Switch-1 -> ISP
- If
L3-Switch-3
config the
default route
L3-Switch-1 default route -> ISP , L3-Switch-5 default route -> L3-Switch-3)
ps. I didn't pay attention to the BGP protocol. I'll take note. I appreciate it.
best regards,
Hello @goyourmin ,
- If
L3switch5
L3Switch3
could have two
default routes
L3Switch3
default routes
Hope to help
Giuseppe
Thank you so much for the kind explanation.
I had a lot of confusion about
static route
especially on
L3-Switch-3,4 devices
Then I was also confused about the
default route
Finally, when it is a full mesh, is there a recommended
default route
config?
L3-Switch-1
ip route 172.16.0.0 255.255.0.0 EthernetX/X X.X.X.X nor or 100? name toward L3-Switch-4
ip route 10.0.0.0 255.0.0.0 EthernetX/X X.X.X.X not or 100? name toward L3-Switch-4
-L3-Switch-3
ex)
ip route 0.0.0.0 0.0.0.0 EthernetX/X X.X.X.X 100 name toward L3-Switch-2
-L3-Switch-4
ex)
ip route 0.0.0.0 0.0.0.0 EthernetX/X X.X.X.X 100 name toward L3-Switch-1
Best regards,
