ASR9006 Max Routes
Daniel Graham
What are the IPv4 and IPv6 max routes for ASR9006 platform (specifically with A9K-RSP440-SE)?
Mark Elsen
- Ref : https://www.cisco.com/c/en/us/support/docs/routers/asr-9000-series-aggregation-services-routers/116999-problem-line-card-00.html
 An ASR 9000 Trident-based line card can support a maximum of 512,000 Layer 3 (L3) prefixes by default. This limit can easily be reached when the router carries the full Internet table as well as Interior Gateway Protocol (IGP) routes and L3 VPN routes.
Typhoon-based (Enhanced Ethernet) line cards support more prefixes by default, so they have more capacity and generally do not require tuning. A Typhoon-based line card supports four million IPv4 and two million IPv6 prefixes by default.
See ASR 9000 Series Line Card Types for an explanation of the differences between Trident-based and Typhoon-based line cards.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Mark Elsen
 M.
       Beauty and terror
      Just keep going
       No feeling is final
Thank you
