i'm looking for an Access Router to connect sites with up to 1Gbit over an Fibre Ethernet Link to a central access Router.
The LAN site will be connected over a 802.1q trunk to an (non) cisco switch and there will be four IP-Adresses on four subinterfaces. QoS is used, one VLAN is used for VOIP.
A Third Port will be used for a small Bandwidth backup Link (SDSL or low Bandwidth Ethernet)
It`s planned to use BGP as Routing Protocol to the the Central Access Router.
Is the new ASR901 Router a good device for this? For example the Model A901-6CZ-F-A? I saw, that this box is positioned for another market (Mobile Wireless Access). Is this device a real router?
Compared to a "normal" Router, e.g. a 3925E are there any important differences? What what be your recommondation?
