ASR907 IOS XE Upgrade
Thomas Graf
I try to upgrade an ASR907 with dual RSP3C from IOS 16.6.1 -> 16.6.3. The installation script failed with the error message: FAILED: ISSU compatibility check failed. I removed the whole config execpt the Line"redundancy mode sso".
--- Starting ISSU compatibility verification ---
*Mar 29 16:30:11.005: %IOSXE-3-PLATFORM:  SIP1: Mar 29 16:30:11 provision.sh: %INSTALL-3-OPERATION_ERROR_MESSAGE: Failed to install package stby-bootflash:Image/*rsp3-*03.18.04.SP.156-2.SP4-ext*.pkg, Error: ISSU compatibility check failed
*Mar 29 16:30:16.639: %IOSXE-5-PLATFORM:  SIP0: Mar 29 16:30:16 provision.sh: %INSTALL-5-OPERATION_COMPLETED_INFO: Completed install package stby-bootflash:Image/*rsp3-*03.18.04.SP.156-2.SP4-ext*.pkgFAILED: Stage 1 for sub-package node ISSU failed
has anyone had this problem already?
thanks for support!
Samuel De Wever
same issue here; did you found a solution?
