BDI not passing traffic to directly connected interfaces
davejumby
Hi here is a post of my configurations however I'm not able to pass traffic from the router to any device directly connected to the interfaces.
interface GigabitEthernet0/0/0
no ip address
no shutdown
negotiation auto
no mop enabled
no mop sysid
no ip redirects
no ip unreachables
no ip proxy-arp
cdp enable
service instance 11 ethernet
encapsulation dot1q 11
rewrite ingress tag pop 1 symmetric
bridge-domain 11
service instance 12 ethernet
encapsulation dot1q 12
bridge-domain 12
service instance 14 ethernet
encapsulation dot1q 14
bridge-domain 14
service instance 17 ethernet
encapsulation dot1q 17
bridge-domain 17
interface BDI12
description "MTN INTERNET CONNECTION To DC SWITCH"
encapsulation dot1Q 12
vrf forwarding NSSF-HQSC-MTNEDGE-VRF
ip address 10.20.0.1 255.255.255.248
ip nbar protocol-discovery
no shutdown
no mop enabled
no mop sysid
no ip redirects
no ip unreachables
no ip proxy-arp
interface GigabitEthernet0/0/3
description "OUTSIDE LINK TO DC SWITCH 2"
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
negotiation auto
cdp enable
service instance 111 ethernet
bridge-domain 111
service instance 112 ethernet
bridge-domain 112
service instance 114 ethernet
bridge-domain 114
service instance 321 ethernet
encapsulation dot1q 321
bridge-domain 321
interface BDI112
description INTERNET LINK TO MTN
ip address 10.0.0.1 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
I need help here guys the next hops respectively are 10.0.0.2 and 10.20.0.2
try and take the 'encapsulation' off the BDIs:
no ip address
no shutdown
negotiation auto
no mop enabled
no mop sysid
no ip redirects
no ip unreachables
no ip proxy-arp
cdp enable
bridge-domain 12
interface BDI12
--> no encapsulation dot1Q 12
no shutdown
no mop enabled
no mop sysid
no ip redirects
no ip unreachables
no ip proxy-arp
description "OUTSIDE LINK TO ISP 2"
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
negotiation auto
cdp enable
encapsulation dot1q 112
bridge-domain 112
interface BDI112
no ip redirects
no ip unreachables
no ip proxy-arp
20 Replies 20
you are using the same VLANs on different service instances. What are you trying to accomplish ? The service instances should match the VLANs.
Best to provide a schematic drawing, and indicate which devices connected to which port cannot communicate with the router...
The diagram explains what I'm trying to do. ISP (labelled as safaricom and MTN) connects to a switch ,then from switch to the ISP outside interface on the ASR routers. From the ASR routers I have inside interfaces to the switch. So from the routers I cannot ping the ISP ip address which essentially is a next hop since the switches are pure layer 2 . I also cannot ping PC connected to the switch , which has an IP addrress in the same network as the inside interface (next hop to inside interface )
sorry for the confusion. For every bridge domain you need a BDI in order to do anything layer 3 related. You have only two BDIs, and both are in the same VLAN...
davejumby
Ok I have separated the BDIs into different vlans , but but its still not working below is my current config and routing table
no ip address
no shutdown
negotiation auto
no mop enabled
no mop sysid
no ip redirects
no ip unreachables
no ip proxy-arp
cdp enable
bridge-domain 12
interface BDI12
no shutdown
no mop enabled
no mop sysid
no ip redirects
no ip unreachables
no ip proxy-arp
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
negotiation auto
cdp enable
bridge-domain 112
interface BDI112
no ip redirects
no ip unreachables
no ip proxy-arp
sh ip route vrf NSSF-HQSC-MTNEDGE-VRF
Routing Table: NSSF-HQSC-MTNEDGE-VRF
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
a - application route
+ - replicated route, % - next hop override, p - overrides from PfR
Gateway of last resort is not set
41.0.0.0/8 is variably subnetted, 4 subnets, 3 masks
C 41.209.16.144/29 is directly connected, BDI12
L 41.209.16.146/32 is directly connected, BDI12
C 41.209.17.212/30 is directly connected, BDI112
L 41.209.17.213/32 is directly connected, BDI112
what router is this on ? Post the output of
show ver
Cisco IOS XE Software, Version 16.07.01
Cisco IOS Software [Fuji], ASR1000 Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 16.7.1, RELEASE SOFTWARE (fc6)
Copyright (c) 1986-2017 by Cisco Systems, Inc.
Compiled Mon 20-Nov-17 19:01 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2017 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
NSSF-HQSC-IEG-2 uptime is 1 week, 4 days, 19 hours, 29 minutes
Uptime for this control processor is 1 week, 4 days, 19 hours, 30 minutes
System returned to ROM by PowerOn
System image file is "bootflash:/asr1001x-universalk9.16.07.01.SPA.bin"
Last reload reason: PowerOn
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Type: Permanent
License Level: ipbase
Next reload license Level: ipbase
cisco ASR1001-X (1NG) processor (revision 1NG) with 3860303K/6147K bytes of memory.
Processor board ID FXS2217Q337
6 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
8388608K bytes of physical memory.
6594559K bytes of eUSB flash at bootflash:.
0K bytes of WebUI ODM Files at webui:.
no ip address
no shutdown
negotiation auto
no mop enabled
no mop sysid
no ip redirects
no ip unreachables
no ip proxy-arp
cdp enable
bridge-domain 12
interface BDI12
no shutdown
no mop enabled
no mop sysid
no ip redirects
no ip unreachables
no ip proxy-arp
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
negotiation auto
cdp enable
bridge-domain 112
interface BDI112
no ip redirects
no ip unreachables
no ip proxy-arp
Hi Georg
Thanks so much your suggestion worked , however I'm facing something very strange ,from 10.20.0.1 I cant ping 10.20.0.2. , however the reverse works perfectly and I can ping 10.0.0.2 as well. Here is my
show ip arp
output. Any help with this ?
Protocol           Address           Age(min)            Hardware Addr                 Type Interface
Internet               10.20.0.1               -                780c.f071.XXX ARPA                 BDI12
Internet               10.20.0.2             5                  3c97.0e25.XXXX ARPA              BDI12
Internet               10.0.0.1 -                                780c.f071.XXX ARPA                 BDI112
Internet                10.0.0.2              4                  370df.2fbd.XXX ARPA                BDI112
where (which port) is 10.20.0.2 connected to ?
Its connected to
gig 0/0/0
its the
next hop to int BDI 12 (10.20.0.1)
does the next hop use a BDI as well (and is the next hop interface in the same vrf ) ? If possible, post the config of the next hop device as well...
Hi the next hop is a firewall , doesn't have configs since its GUI, so just an IP address , however I have tried replacing the firewall with a PC and assigning it the firewall IP address and I'm getting similar results I can ping from the firewall/PC but from the router I cannot ping either.
can you post the output of:
show ip route vrf NSSF-HQSC-MTNEDGE-VRF
here it is
10.0.0.0/8 is variably subnetted, 4 subnets, 3 masks
C 10.20.0.0/29 is directly connected, BDI12
L 10.20.0.1/32 is directly connected, BDI12
C 10.0.0.0/30 is directly connected, BDI112
L 10.0.0.1/32 is directly connected, BDI112
