ASR920 12SZ FPGA UPGRADE Done : Reboot Loop
mrandrewwww
After I reset from rommon config 0x2142, the router always reboots repeatedly, how do I solve it?please help
BR
Edson A. Hernandez
After booting with the 0x2142 setting, ensure you change the configuration register back to the default value (commonly 0x2102) after making any necessary changes to the configuration.
The error message related to the authoritative clock suggests there might be an issue with the time settings on the device. Ensure the clock is set correctly and that any NTP settings are accurate.
Common causes for boot loops include configuration issues, hardware problems, and corrupted IOS images. If possible, check the hardware for any visible issues, verify the IOS image, and consider booting from an alternative image if one is available.
If you're unable to resolve the issue on your own, you might need to contact Cisco's Technical Assistance Center (TAC) or seek help on networking forums where you can share more detailed logs and get advice from other networking professionals.
cisco ASR-920-12SZ-D (Freescale T1042) processor (revision 1.2 GHz) with 896057K/6147K bytes of memory.
Processor board ID FOC2534R20S
12 Ten Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
3670016K bytes of physical memory.
3089999K bytes of eMMC flash at bootflash:.
%INIT: waited 0 seconds for NVRAM to be available
Press RETURN to get started!
*Nov 6 17:09:11.919: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = ASR-920-12SZ-D Next reboot level = advancedmetroipaccess and License = advancedmetroipaccess
*Nov 6 17:09:20.081: %SMART_LIC-6-AGENT_READY: Smart Agent for Licensing is initializedAllocate serdes lanes for 0/0
*Nov 6 17:09:26.478: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlanCannot Get the number of ports in MAC notification
*Nov 6 17:09:28.158: [IOX DEBUG] IOx subsystem is inlcuded but it is marked as not needed
*Nov 6 17:09:28.364: %LINK-3-UPDOWN: Interface Lsmpi0, changed state to up
*Nov 6 17:09:28.369: %LINK-3-UPDOWN: Interface EOBC0, changed state to up
*Nov 6 17:09:28.370: %LINEPROTO-5-UPDOWN: Line protocol on Interface LI-Null0, changed state to up
*Nov 6 17:09:28.371: %LINK-3-UPDOWN: Interface GigabitEthernet0, changed state to down
*Nov 6 17:09:28.373: %IOSXE_RP_ALARM-6-INFO: asserted CRITICAL GigabitEthernet0: Physical Port Link Down
*Nov 6 17:09:28.412: %LINK-3-UPDOWN: Interface LIIN0, changed state to up
*Nov 6 17:09:29.220: %LINEPROTO-5-UPDOWN: Line protocol on Interface Lsmpi0, changed state to up
*Nov 6 17:09:29.220: %LINEPROTO-5-UPDOWN: Line protocol on Interface EOBC0, changed state to up
*Nov 6 17:09:29.221: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to down
*Nov 6 17:09:29.222: %LINEPROTO-5-UPDOWN: Line protocol on Interface LIIN0, changed state to up
*Nov 6 17:09:29.585: %IOSXE_MGMTVRF-6-CREATE_SUCCESS_INFO: Management vrf Mgmt-intf created with ID 1, ipv4 table-id 0x1, ipv6 table-id 0x1E000001
*Nov 6 17:09:32.901: %SYS-4-CONFIG_NEWER: Configuration from version 17.3 may not be correctly understood
*Nov 6 17:07:57.719: %CMEM-3-SENSOR_INIT_FAILED: R0/0: emd: Sensor (PEM Iout) initialization failed due to No such file or directory.
*Nov 6 17:08:19.257: %HANDOFF_FUD-6-HOFPGA_DOWNGRADE: R0/0: cylon_mgr: Handoff FPGA is downgrading to 0x1001a from current FPGA version 0x20043, as downgrade is required for current release
*Nov 6 17:08:19.258: %HANDOFF_FUD-6-HOFPGA_DOWNGRADE_STARTED: R0/0: cylon_mgr: Starting Handoff FPGA downgrade
*Nov 6 17:09:33.425: %SYS-5-CONFIG_I: Configured from memory by console
*Nov 6 17:09:33.471: %IOSXE_OIR-6-REMSPA: SPA removed from subslot 0/0, interfaces disabled
*Nov 6 17:09:33.558: %SPA_OIR-6-OFFLINECARD: SPA (12xGE-10GE-FIXED) offline in subslot 0/0
*Nov 6 17:09:33.593: %IOSXE_RP_ALARM-2-PEM: asserted CRITICAL Power Supply Module 1: Power Supply Failure
*Nov 6 17:09:33.788: %IOSXE_RP_ALARM-6-INFO: cleared CRITICAL GigabitEthernet0: Physical Port Link Down
*Nov 6 17:09:33.930: %SYS-5-RESTART: System restarted --
Cisco IOS Software [Fuji], ASR920 Software (PPC_LINUX_IOSD-UNIVERSALK9_NPE-M), Version 16.9.1a, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2018 by Cisco Systems, Inc.
Compiled Thu 26-Jul-18 18:08 by mcpre
*Nov 6 17:09:35.392: %IOSXE_OIR-6-INSCARD: Card (fp) inserted in slot F0
*Nov 6 17:09:35.392: %IOSXE_OIR-6-ONLINECARD: Card (fp) online in slot F0
*Nov 6 17:09:35.405: %IOSXE_OIR-6-INSCARD: Card (cc) inserted in slot 0
*Nov 6 17:09:35.405: %IOSXE_OIR-6-ONLINECARD: Card (cc) online in slot 0
*Nov 6 17:09:35.568: %IOSXE_OIR-6-INSSPA: SPA inserted in subslot 0/0
*Nov 6 17:09:37.059: %FMFP-3-OBJ_DWNLD_TO_DP_STUCK: R0/0: fman_fp_image: AOM download of obj[1] type[318] Resync end event?]+ to Data Plane is stuck for more than 120 secondsAllocate serdes lanes for 0/0
*Nov 6 17:09:38.978: %IOSXE_RP_ALARM-6-INFO: asserted MAJOR FIXED IM subslot 0/0: Boot state
*Nov 6 17:09:42.423: %PNP-6-PNP_DISCOVERY_STOPPED: PnP Discovery stopped (Startup Config Present)
*Nov 6 17:09:42.425: %ONEP_BASE-6-SS_ENABLED: ONEP: Service set Base was enabled by Default
*Nov 6 17:09:47.566: %PKI-2-NON_AUTHORITATIVE_CLOCK: PKI functions can not be initialized until an authoritative time source, like NTP, can be obtained.
FPGA UPGRADE Done: System going for reboot
here is the log can you help me analyze it?please
BR
T800120
I have the same problem, i wanted to update the ios from 16.09.03 to 16.12.07 but i am facing the same issue now.
Proceed with reload? [confirm]
*Oct 3 12:30:27.913: %SYS-5-RELOAD: Reload requested by console. Reload Reason: Reload Command.Oct 3 12:30:48.551: %PM
AN-5-EXITACTION: C0/0: pvp: Process manager is exiting: reload fru action requested
Oct 3 12:30:54.280: %PMAN-5-EXITACTION: F0/0: pvp: Process manager is exiting: reload fru action requested
Oct 3 12:30:55.632: %PMAN-5-EXITACTION: R0/0: pvp: Process manager is exiting: process exit with reload chassis code
øUEA platform with 3670016 Kbytes of main memory
boot: unsupported boot device "flash"
autoboot: boot failed, restarting...
no valid BOOT image found
Final autoboot attempt from default boot device...
Located FOC2710R2V6_20230316_094011.lic
Image size 1164 inode num 13, bks cnt 1 blk size 8*512
Boot image size = 1164 (0x48c) bytes
pid_str[ASR-920-12CZ-A]
ROM:RSA Self Test hash Mismatch in long long word No. 0
ROM:Sha512 Self Test
Unknown image structure
Located pnp-tech-time
Image size 35 inode num 14, bks cnt 1 blk size 8*512
Boot image size = 35 (0x23) bytes
Unsigned package found, ... continuing ...
Located pnp-tech-discovery-summary
Image size 56371 inode num 15, bks cnt 14 blk size 8*512
Boot image size = 56371 (0xdc33) bytes
Located asr920-universalk9_npe.16.12.07.SPA.bin
Image size 467893383 inode num 16, bks cnt 114232 blk size 8*512
Boot image size = 467893383 (0x1be37c87) bytes
Package header rev 2 structure detected
Calculating SHA-1 hash...done
validate_package_cs: SHA-1 hash:
calculated bc3bc24b:cf7d6ae6:dba91d3f:8b9dfc5c:328d84d5
expected bc3bc24b:cf7d6ae6:dba91d3f:8b9dfc5c:328d84d5
RSA Signed RELEASE Image Signature Verification Successful.
Image validated
Passing control to the main image..
Stage2 Bootldr for Polaris-image
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
Cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software [Gibraltar], ASR920 Software (PPC_LINUX_IOSD-UNIVERSALK9_NPE-M), Version 16.12.7, RELEASE SOFTWARE (f
c2)
Copyright (c) 1986-2022 by Cisco Systems, Inc.
Compiled Wed 02-Feb-22 06:35 by mcpre
PLEASE READ THE FOLLOWING TERMS CAREFULLY. INSTALLING THE LICENSE OR
LICENSE KEY PROVIDED FOR ANY CISCO SOFTWARE PRODUCT, PRODUCT FEATURE,
AND/OR SUBSEQUENTLY PROVIDED SOFTWARE FEATURES (COLLECTIVELY, THE
"SOFTWARE"), AND/OR USING SUCH SOFTWARE CONSTITUTES YOUR FULL
ACCEPTANCE OF THE FOLLOWING TERMS. YOU MUST NOT PROCEED FURTHER IF YOU
ARE NOT WILLING TO BE BOUND BY ALL THE TERMS SET FORTH HEREIN.
Your use of the Software is subject to the Cisco End User License Agreement
(EULA) and any relevant supplemental terms (SEULA) found at
http://www.cisco.com/c/en/us/about/legal/cloud-and-software/software-terms.html.
You hereby acknowledge and agree that certain Software and/or features are
licensed for a particular term, that the license to such Software and/or
features is valid only for the applicable term and that such Software and/or
features may be shut down or otherwise terminated by Cisco after expiration
of the applicable license term (e.g., 90-day trial period). Cisco reserves
the right to terminate any such Software feature electronically or by any
other means available. While Cisco may provide alerts, it is your sole
responsibility to monitor your usage of any such term Software feature to
ensure that your systems and networks are prepared for a shutdown of the
Software feature.
All TCP AO KDF Tests Pass
