ASR1002 redundancy failure, state "init, standby"
Steffen Pontiac
Hi Community,
that is my first post here so please be patient. ;-)
On many of our ASR1002-X and -HX router I see the following:
Router1#sh platform
Chassis type: ASR1002-X
Slot Type State Insert time (ago)
0 ASR1002-X ok 17:14:40
0/0 6XGE-BUILT-IN ok 17:13:31
R0 ASR1002-X ok 17:14:40
R0/0 ok, active 17:14:40
R0/1 init, standby 17:13:01
F0 ASR1002-X ok, active 17:14:40
P0 ASR1002-PWR-AC ok 17:14:20
P1 ASR1002-PWR-AC ok 17:14:20
Slot CPLD Version Firmware Version
0 14012203 16.2(1r)
R0 14012203 16.2(1r)
F0 14012203 16.2(1r)
Router1#sh redundancy states
my state = 13 -ACTIVE
peer state = 1 -DISABLED
Mode = Duplex
Unit = Primary
Unit ID = 48
Redundancy Mode (Operational) = sso
Redundancy Mode (Configured) = sso
Redundancy State = sso
Maintenance Mode = Disabled
Manual Swact = disabled (the peer unit is still initializing)
Communications = Down Reason: Failure
client count = 119
client_notification_TMR = 30000 milliseconds
RF debug mask = 0x0
Router2#sh platform
Chassis type: ASR1002-HX
0 ASR1002-HX ok 2y11w
0/0 BUILT-IN-EPA-8x1G ok 2y11w
0/1 BUILT-IN-EPA-8x10G ok 2y11w
R0 ASR1002-HX ok 2y11w
R0/0 ok, active 2y11w
R0/1 init, standby 2y11w
F0 ASR1002-HX ok, active 2y11w
P0 ASR1000X-AC-750W ok 2y11w
P1 ASR1000X-AC-750W ok 2y11w
P2 ASR1002HX-FAN ok 2y11w
0 15100715 16.2(2r)
R0 15100715 16.2(2r)
F0 15100715 16.2(2r)
Router2#sh redundancy states
Mode = Duplex
Unit = Primary
Unit ID = 48
client count = 119
RF debug mask = 0x0
Do you have any commands for me to find out what is producing the failure?
I tried using the following debug command but did not catch any event:
debug redundancy kpa
debug redundancy errors
debug redundancy status
debug redundancy info
debug redundancy idb-sync-history
Router1 uses Version 16.3.5
Router2 uses Version 16.3.3
Thanks guys!
Steffen
11 Replies 11
Mark Elsen
 - Please post the output of show platform diag
  M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Steffen Pontiac
Router1#sh platform diag
Slot: 0, ASR1002-HX
Running state : ok
Internal state : online
Internal operational state : ok
Physical insert detect time : 00:00:37 (2y11w ago)
Software declared up time : 00:01:08 (2y11w ago)
CPLD version : 15100715
Firmware version : 16.2(2r)
Sub-slot: 0/0, BUILT-IN-EPA-8x1G
Operational status : ok
Internal state : inserted
Physical insert detect time : 00:01:33 (2y11w ago)
Logical insert detect time : 00:01:33 (2y11w ago)
Sub-slot: 0/1, BUILT-IN-EPA-8x10G
Physical insert detect time : 00:01:34 (2y11w ago)
Logical insert detect time : 00:01:34 (2y11w ago)
Slot: R0, ASR1002-HX
Running state : ok
Software declared up time : 00:00:37 (2y11w ago)
Sub-slot: R0/0,
Running state : ok, active
Logical insert detect time : 00:00:37 (2y11w ago)
Sub-slot: R0/1,
Running state : init, standby
Logical insert detect time : 00:02:01 (2y11w ago)
Slot: F0, ASR1002-HX
Software declared up time : 00:01:03 (2y11w ago)
Hardware ready signal time : 00:01:02 (2y11w ago)
Packet ready signal time : 00:01:35 (2y11w ago)
Slot: P0, ASR1000X-AC-750W
State : ok
Physical insert detect time : 00:00:53 (2y11w ago)
Slot: P1, ASR1000X-AC-750W
State : ok
Slot: P2, ASR1002HX-FAN
State : ok
Physical insert detect time : 00:00:52 (2y11w ago)
Router2#sh platform diag
Slot: 0, ASR1002-X
Running state : ok
Physical insert detect time : 00:00:20 (19:32:09 ago)
Software declared up time : 00:00:55 (19:31:34 ago)
CPLD version : 14012203
Firmware version : 16.2(1r)
Sub-slot: 0/0, 6XGE-BUILT-IN
Physical insert detect time : 00:01:29 (19:31:00 ago)
Logical insert detect time : 00:01:29 (19:31:00 ago)
Slot: R0, ASR1002-X
Running state : ok
Software declared up time : 00:00:20 (19:32:09 ago)
Sub-slot: R0/0,
Logical insert detect time : 00:00:20 (19:32:09 ago)
Sub-slot: R0/1,
Logical insert detect time : 00:01:59 (19:30:30 ago)
Slot: F0, ASR1002-X
Software declared up time : 00:01:14 (19:31:15 ago)
Hardware ready signal time : 00:00:48 (19:31:41 ago)
Packet ready signal time : 00:01:28 (19:31:01 ago)
Slot: P0, ASR1002-PWR-AC
State : ok
Physical insert detect time : 00:00:40 (19:31:49 ago)
Slot: P1, ASR1002-PWR-AC
State : ok
  - If you can easily identify the faulty router-module by for instance a led indicator , try re-seating it, but attach a console to your device first, followup on console messages.
 M.
       Beauty and terror
      Just keep going
       No feeling is final
Hi marce1000, the routers are not locally. BR,Steffen
Cristian Matei
    What does "show redundancy history" say?
Cristian Matei.
I attached both outputs to this post.
BR,
Steffen
    Somehow i missed the second command: " show redundancy".
Cristian Matei.
NP, thanks for helping christian.
Redundant System Information :
Available system uptime = 2 years, 12 weeks, 21 hours, 19 minutes
Switchovers system experienced = 0
Standby failures = 0
Last switchover reason = none
Hardware Mode = Duplex
Configured Redundancy Mode = sso
Operating Redundancy Mode = sso
Communications = Down Reason: Simplex mode
Current Processor Information :
Active Location = slot 6
Current Software state = ACTIVE
Uptime in current state = 2 years, 12 weeks, 21 hours, 19 minutes
Image Version = Cisco IOS Software [Denali], ASR1000 Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 16.3.5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2017 by Cisco Systems, Inc.
Compiled Thu 05-Oct-17 01:20 by mcpre
BOOT = bootflash:asr1000-universalk9.16.03.05.SPA.bin,1;bootflash:,1;
CONFIG_FILE =
Configuration register = 0x2102
Peer (slot: 7) information is not available because it is in 'DISABLED' state
Available system uptime = 3 days, 15 hours, 35 minutes
Uptime in current state = 3 days, 15 hours, 35 minutes
Image Version = Cisco IOS Software [Denali], ASR1000 Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 16.3.3, RELEASE SOFTWARE (fc3)
Compiled Tue 28-Feb-17 06:09 by mcpre
    I see "Peer (slot: 7) information is not available because it is in 'DISABLED' state". Usually this is a hardware issue (needs RMA), or a proper reseat of the module.
Cristian Matei.
Hi Christian,
sorry for the late replay.
Since we have the "Init" state message on a couple of ASR1K Router it looks more like an Software issue to me.
I have to check them to get an overview of the affected routers and open a TAC case to let them investigate the issue.
@christian and Marce
Thanks for participating to my question. ;-)
BR,
Steffen
terencepowell
Hey Steffen,
I know it's been several years since dealing with this matter but did you ever find a solution? I have the exact same issue as you describe above.
Thanks!
Terence
