ASR920 BGP on BDI interface doesn't work
spadhausen
Hello, I have a big issue:
ASR920 with 2x 10GBe on a port channel to my uplink (0.0.0.0) and BGP running OK
2x10GBe on a port channel where I receive qnq vlans.
I have created a BDI interface, I can ping the remote ends with no issue.
The issue is that I cannot reach via telnet nor run BGP on the BVI.
I set a /30 ip on the BDI, I can ping and trace the remote end (no ACL, no filters, nothing). I cannot telnet the remote end, nor BGP.
Is there a limitation of the BGP functionality on BDI interface on ASR920?
ASR920MIX#sh ver
Cisco IOS XE Software, Version 17.06.02
Cisco IOS Software [Bengaluru], ASR920 Software (PPC_LINUX_IOSD-UNIVERSALK9_NPE-M), Version 17.6.2, RELEASE SOFTWARE (fc7)
Copyright (c) 1986-2021 by Cisco Systems, Inc.
Compiled Tue 23-Nov-21 10:17 by mcpre
ROM: 15.6(48r)
ASR920MIX uptime is 9 weeks, 1 day, 21 hours, 39 minutes
Uptime for this control processor is 9 weeks, 1 day, 21 hours, 46 minutes
System returned to ROM by reload at 23:05:24 ITALY Thu Dec 19 2024
System restarted at 15:04:46 ITALY Fri Dec 20 2024
System image file is "bootflash:asr920-universalk9_npe.17.06.02.SPA.bin"
Last reload reason: PowerOn
License Level: advancedmetroipaccess
License Type: Permanent
Next reload license Level: advancedmetroipaccess
Smart Licensing Status: Smart Licensing is DISABLED
cisco ASR-920-4SZ-A (Freescale P2020) processor (revision 1.0 GHz) with 864646K/6147K bytes of memory.
Processor board ID CAT2230U0TC
2 Gigabit Ethernet interfaces
4 Ten Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
3670016K bytes of physical memory.
1231647K bytes of eMMC flash at bootflash:.
I have also tried to create a loopback interface and run BGP from there, with no success.
interface Loopback1
description virtual interface for BGP
ip address 100.80.2.110 255.255.255.255
no ip redirects
no ip proxy-arp
interface Port-channel2
mtu 9000
no ip address
no ip redirects
no ip proxy-arp
service instance 306 ethernet
encapsulation dot1q 306 second-dot1q 10
rewrite ingress tag pop 2 symmetric
bridge-domain 11 split-horizon group 0
interface BDI11
ip address 100.80.5.1 255.255.255.252
no ip redirects
no ip proxy-arp
TEST: If I set the remote neighbour 100.80.5.2: doesnt work, the peer is DIRECTLY CONNECTED
If I set a remote loopback on the remote device and set a static route, DONT WORK
If I remove the static route and the path to the remote loopback address goes through wan with another route, works.
The are NO FILTERS, just a bunch of qnq in the port-channel2
Seems that when traffic goes through BDI it doesnt work.
Dr. Spadoni
34 Replies 34
Sorry
To the juniper there is a port-channel usign 2x10G, everything is OK there. there is a /29 directly connected and it works OK.
The issue is on the BDI interface! Everything going out from the BDI interface is not working.
My final question is:
Are there any limitations doing BGP on the BDI interface?
Does the BDI interface has any limitations doing telnet/BGP and so on?
I have a peer on the BDI interface, directly connected via /30 and BGP is not working there. No packet goes outside nor the BGP port on the BDI interface is reachable,
Dr. Spadoni
use static route for LO dont use default route
MHM
But the sessiom doesnt work even on directly connected interface on /30 on BDI. On physical interface it works
Dr. Spadoni
Ok'
Start
Debug ip bgp <<-
Debug tcp <<-
MHM
I have finally found the issue.
The metro-eth ISP DROPS every packet that is not marked as COS0.
The issue is that BGP goes out from the interface in COS6.
On the ASR920 I cannot set an egress policy on a BDI interface.
I have replaced it with a 1001X, and it doesn't need any policy since the BGP traffic is not marked with a predetermined COS.
Dr. Spadoni
