ASR920 CoPP not working
bozo.bogd
Hi guys,
I seem to have an issue with control-plane policing with ASR-920-24SZ-M.
Configuration is accepted, applied but traffic just doesn't hit it.
I'am running version asr920-universalk9_npe.16.09.05f.SPA.bin
ACL's are simplified as much as they can be, following  :
https://www.cisco.com/c/en/us/td/docs/routers/asr920/configuration/guide/qos/qos-plcshp-xe-3-13s-asr920-book/qos-plcshp-xe-3-13s-asr920-book_chapter_011.html
configuration :
Extended IP access list COPP-DEFAULT-ACL
10 permit ip any any
Extended IP access list COPP-DENIED-ACL
10 permit tcp any any eq telnet
20 permit tcp any eq telnet any established
30 permit tcp any any eq 22
40 permit tcp any eq 22 any established
50 permit udp any any eq snmp
60 permit udp any any eq ntp
70 permit udp any any eq 443
80 permit udp any any eq 80
90 permit tcp any any eq ftp
100 permit tcp any any eq ftp-data
110 permit tcp any any eq bgp rst
Extended IP access list COPP-MANAGEMENT-ACL
10 permit ip 192.168.1.0 0.0.0.255 any
Extended IP access list COPP-NORMAL-ACL
10 permit icmp any any echo
20 permit icmp any any echo-reply
Extended IP access list COPP-ROUTING-ACL
20 permit tcp any eq bgp any
IPv6 access list IPV6-COPP-DEFAULT-ACL
permit ipv6 any any sequence 10
IPv6 access list IPV6-COPP-DENIED-ACL
permit tcp any any eq telnet sequence 10
permit tcp any eq telnet any established sequence 20
permit tcp any any eq 22 sequence 30
permit tcp any eq 22 any established sequence 40
permit udp any any eq snmp sequence 50
permit udp any any eq ntp sequence 60
permit udp any any eq 443 sequence 70
permit udp any any eq 80 sequence 80
permit tcp any any eq ftp sequence 90
permit tcp any any eq ftp-data sequence 100
IPv6 access list IPV6-COPP-MANAGEMENT-ACL
permit ipv6 2A03:7777:2::/48 any sequence 10
IPv6 access list IPV6-COPP-ROUTING-ACL
permit tcp any any eq bgp sequence 10
permit tcp any eq bgp any sequence 20
class-map match-any COPP-DENIED
match access-group name COPP-DENIED-ACL
class-map match-all IPV6-COPP-ROUTING
match access-group name IPV6-COPP-ROUTING-ACL
class-map match-all COPP-MANAGEMENT
match access-group name COPP-MANAGEMENT-ACL
class-map match-any COPP-NORMAL
match access-group name COPP-NORMAL-ACL
class-map match-any IPV6-COPP-DEFAULT
match access-group name IPV6-COPP-DEFAULT-ACL
class-map match-all IPV6-COPP-MANAGEMENT
match access-group name IPV6-COPP-MANAGEMENT-ACL
class-map match-any IPV6-COPP-NORMAL
match access-group name IPV6-COPP-NORMAL-ACL
class-map match-any COPP-DEFAULT
match access-group name COPP-DEFAULT-ACL
class-map match-any IPV6-COPP-DENIED
match access-group name IPV6-COPP-DENIED-ACL
class-map match-all COPP-ROUTING
match access-group name COPP-ROUTING-ACL
for testing purpose everything is set to transmit :
policy-map COPP
class COPP-ROUTING
police 1000000 187500 conform-action transmit exceed-action transmit
class IPV6-COPP-ROUTING
police 10000000 187500 conform-action transmit exceed-action transmit
class COPP-MANAGEMENT
police 10000000 18750 conform-action transmit exceed-action transmit
class IPV6-COPP-MANAGEMENT
class COPP-DENIED
police 64000 pir 64000 conform-action transmit exceed-action transmit violate-action transmit
class IPV6-COPP-DENIED
class COPP-NORMAL
police 64000 12000 pir 64000 conform-action transmit exceed-action transmit violate-action transmit
class IPV6-COPP-NORMAL
class COPP-DEFAULT
police 64000 8000 pir 64000 conform-action transmit exceed-action transmit violate-action transmit
class IPV6-COPP-DEFAULT
control-plane
service-policy input COPP
output :
asr12#show policy-map control-plane
Control Plane
Service-policy input: COPP
Class-map: COPP-ROUTING (match-all)
0 packets, 0 bytes
5 minute offered rate 0000 bps, drop rate 0000 bps
Match: access-group name COPP-ROUTING-ACL
police:
cir 1000000 bps, bc 187500 bytes
conformed 0 packets, 0 bytes; actions:
transmit
exceeded 0 packets, 0 bytes; actions:
transmit
conformed 0000 bps, exceeded 0000 bps
Class-map: IPV6-COPP-ROUTING (match-all)
0 packets, 0 bytes
Match: access-group name IPV6-COPP-ROUTING-ACL
police:
cir 10000000 bps, bc 187500 bytes
transmit
transmit
Class-map: COPP-MANAGEMENT (match-all)
0 packets, 0 bytes
Match: access-group name COPP-MANAGEMENT-ACL
police:
cir 10000000 bps, bc 18750 bytes
transmit
transmit
Class-map: IPV6-COPP-MANAGEMENT (match-all)
0 packets, 0 bytes
Match: access-group name IPV6-COPP-MANAGEMENT-ACL
police:
transmit
transmit
Class-map: COPP-DENIED (match-any)
0 packets, 0 bytes
Match: access-group name COPP-DENIED-ACL
police:
cir 64000 bps, bc 8000 bytes
pir 64000 bps, be 8000 bytes
transmit
transmit
violated 0 packets, 0 bytes; actions:
transmit
conformed 0000 bps, exceeded 0000 bps, violated 0000 bps
Class-map: IPV6-COPP-DENIED (match-any)
0 packets, 0 bytes
Match: access-group name IPV6-COPP-DENIED-ACL
police:
transmit
transmit
transmit
Class-map: COPP-NORMAL (match-any)
0 packets, 0 bytes
Match: access-group name COPP-NORMAL-ACL
police:
cir 64000 bps, bc 12000 bytes
transmit
transmit
transmit
Class-map: IPV6-COPP-NORMAL (match-any)
0 packets, 0 bytes
Match: access-group name IPV6-COPP-NORMAL-ACL
police:
transmit
transmit
transmit
Class-map: COPP-DEFAULT (match-any)
0 packets, 0 bytes
Match: access-group name COPP-DEFAULT-ACL
police:
transmit
transmit
transmit
Class-map: IPV6-COPP-DEFAULT (match-any)
0 packets, 0 bytes
Match: access-group name IPV6-COPP-DEFAULT-ACL
police:
transmit
transmit
transmit
Class-map: class-default (match-any)
0 packets, 0 bytes
Match: any
Any idea would be much appreciated
Thank you
network_baba
Did you ever get any resolution on this? Having a very similar situation on 16.12.3 on ASR920-4SZ
network_baba
was able to fix my issue, not sure about you though.
ASR920 platform has a TCAM limit on the ACL size that can be applied to the Control-Plane. I think it's like 127 ACEs. And also, I don't think it supports IPv6 for COPP.
