ASR9910: Error in the logs
jds5
Does anyone know the exact meaning of these messages (errors)?:
RP/0/RSP0/CPU0:HRDOP18#sh log last 100 | i RP-RED-LOST-NSRNR
Wed Nov 9 10:13:20.773 CET
RP/0/RSP0/CPU0:Nov 9 08:23:25.575 CET: rmf_svr[132]: %PKT_INFRA-FM-3-FAULT_MAJOR : ALARM_MAJOR :RP-RED-LOST-NSRNR :DECLARE :0/RSP0/CPU0:
RP/0/RSP0/CPU0:Nov 9 08:25:43.038 CET: rmf_svr[132]: %PKT_INFRA-FM-3-FAULT_MAJOR : ALARM_MAJOR :RP-RED-LOST-NSRNR :CLEAR :0/RSP0/CPU0:
RP/0/RSP0/CPU0:Nov 9 09:04:24.121 CET: rmf_svr[132]: %PKT_INFRA-FM-3-FAULT_MAJOR : ALARM_MAJOR :RP-RED-LOST-NSRNR :DECLARE :0/RSP0/CPU0:
RP/0/RSP0/CPU0:Nov 9 09:04:41.624 CET: rmf_svr[132]: %PKT_INFRA-FM-3-FAULT_MAJOR : ALARM_MAJOR :RP-RED-LOST-NSRNR :CLEAR :0/RSP0/CPU0:
Is it critical? What should be done with this kind of message?
BR,
marce1000
 - Ref : https://bst.cloudapps.cisco.com/bugsearch?pf=prdNm&kw=RP-RED-LOST-NSRNR&bt=custV&sb=anfr , possible first one reported is a match  , not fully accessible but  summary available in right pane. Or you may connect to the ASR  with : https://cway.cisco.com/cli , at the top left run (or press) 'System Diagnostics'.
  Always advisable is to use latest advisory release and check if the problem remainshttps://software.cisco.com/download/home/286309459/type/280805694/release/7.5.2
 M.
