ASR9K cli command corruption
ituskes
We have recently upgarded ASR9K to 6.5.3 64 bit eXR.
More of us experienced this behaviour,
longer commands or configuration lines entered,
tried to use the previous command and edit it,
the output get corrupted and failed to execute.
It happens after Ctrl-p, Ctrl-a and edit something like interface id...
Can not reproduce in cXRs.
RP/0/RSP0/CPU0:asr9k1-spA#show qos interface tenGigE 0/1/0/0.661 output
Thu Nov 28 14:42:51.508 CET
Interface: TenGigE0_1_0_0.661 output
ed Weight: 10 Excess Weight: 10
Bandwidth: 0 kbps, BW sum for Level 0: 0 kbps, Excess Ratio: 1
RP/0/RSP0/CPU0:asr9k1-spA#show q interf tenGigE 00/0.66.661 outputput
% Ambiguous command: "show q interf tenGigE 00/0.66.661 outputput "
RP/0/RSP0/CPU0:asr9k1-spA#show qos interf tenGigE 00/0.66.661 outputput
% Invalid input detected at '^' marker.
RP/0/RSP0/CPU0:asr9k1-spA#R
RP/0/RSP0/CPU0:asr9k1-spA(config)#subscriber redundancy group 661 interface-list interface tenGigE 0/1/1/3.1111 id 123
RP/0/RSP0/CPU0:asr9k1-spA(config)#no subscriber redundancy group 661 interface-list interface tenGigE 0/1/1/3.1111 id 124
RP/0/RSP0/CPU0:asr9k1-spA(config)#no subscriber redundancy group 661 interface-list interface tenGigE 0/1/1/3.1111 id 123
RP/0/RSP0/CPU0:asr9k1-spA(config)# subscriber redundancyroup 661 intercece-list t teacace tenGigE E 0/1/1/3.1111 id 123
0 Replies 0
