Nat routing problem between Cisco c2691 routers
Naeem_Khan
Hello. I am working on a school project and I am very new to networking in general. I have a small network simulation made in GNS 3 with 3 routers (Cisco c2691) connected to each other. Here is the set up below:
4d1d7119d1737605b109ff21b014ed02
My problem is that I am getting Internet on R1 but not on R2 and R3. I cannot even ping 8.8.8.8 from R2 but doing so from R1 works. All of them are routed through OSPF. Here are the configurations of R1 and R2 respectively:
R1:
version 12.4
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
no ip icmp rate-limit unreachable
ip cef
no ip domain lookup
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
ip tcp synwait-time 5
interface FastEthernet0/0
 ip address dhcp
 duplex auto
 speed auto
interface FastEthernet0/1
 ip address 192.168.0.254 255.255.255.0
 duplex auto
 speed auto
interface FastEthernet1/0
interface FastEthernet1/1
interface FastEthernet1/2
interface FastEthernet1/3
interface FastEthernet1/4
interface FastEthernet1/5
interface FastEthernet1/6
interface FastEthernet1/7
interface FastEthernet1/8
interface FastEthernet1/9
interface FastEthernet1/10
interface FastEthernet1/11
interface FastEthernet1/12
interface FastEthernet1/13
interface FastEthernet1/14
interface FastEthernet1/15
interface Vlan1
 no ip address
router ospf 1
 log-adjacency-changes
 area 1 virtual-link 192.168.0.1
 area 2 virtual-link 192.168.0.2
 network 192.168.0.0 0.0.0.255 area 0
ip forward-protocol nd
no ip http server
no ip http secure-server
no cdp log mismatch duplex
control-plane
line con 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
line aux 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
line vty 0 4
 login
end
R2:
version 12.4
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
no ip domain lookup
 ip address 192.168.0.1 255.255.255.0
 duplex auto
 speed auto
 ip address 192.168.1.254 255.255.255.0
 duplex auto
 speed auto
interface Vlan1
 no ip address
router ospf 1
 area 1 virtual-link 192.168.0.254
 network 192.168.1.0 0.0.0.255 area 1
no ip http server
control-plane
line con 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
line aux 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
line vty 0 4
 login
end
I tried doing NAT on R1 as follows:
R1(config)# int f0/0
R1(config-if)# ip nat outside
R1(config-if)# ex
R1(config)# int f0/1
R1(config-if)# ip nat inside
R1(config-if)# ex
R1(config)# access-list 100 remark
R1(config)# access-list 100 permit ip 192.168.0.0 0.0.0.255 any
R1(config)# ip nat inside source list 100 interface f0/0 overload
But that did not help either. Is there any way to get internet traffic in R2/R3 and every other network connected to it? Any help would be really appreciated as I have tried every possible way I know of.
Paul's suggestion does the trick, the 'default-information originate always' sends the default route to the other routers. For the sake of completeness, if you do want to use different areas, below are the configs you could use (I added loopback which are typically used as router IDs for OSPF, and an IOS DHCP server to R2 for your VPCS client):
R1
hostname R1
interface Loopback 1
ip address 1.1.1.1 255.255.255.255
ip address dhcp
ip nat outside
duplex auto
speed auto
ip nat inside
duplex auto
speed auto
router ospf 1
router-id 1.1.1.1
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0 dhcp
ip nat inside source list 1 interface FastEthernet0/0 overload
access-list 1 permit 192.168.0.0 0.0.255.255
R2
hostname R2
ip dhcp excluded-address 192.168.1.254
ip dhcp pool LAN
network 192.168.1.0 255.255.255.0
default-router 192.168.1.254
dns-server 8.8.8.8 8.8.4.4
interface Loopback 2
ip address 2.2.2.2 255.255.255.255
duplex auto
speed auto
duplex auto
speed auto
router ospf 1
router-id 2.2.2.2
R3
hostname R3
interface Loopback 3
ip address 3.3.3.3 255.255.255.255
ip address 192.168.0.2 255.255.255.0
duplex auto
speed auto
ip address 192.168.2.254 255.255.255.0
duplex auto
speed auto
router ospf 1
router-id 3.3.3.3
network 192.168.2.0 0.0.0.255 area 2
8 Replies 8
remove all the virtual links from all 3 routers.
Hello. That did not work for me. I still do not have access to the internet
on R2 or R3.
can you ping the WAN IP address of R1 from R2 and R3 ?
I can ping f0/1 of R1 from R2, R3 and PC1, but not f0/0 of R1. Is that the
issue?
on R1, add a static default route:
Hello
R1
router ospf 1
network 192.168.0.1 0.0.0.0 area 0
ip route 0.0.0.0 0.0.0.0 fa0/0 dhcp
access-list 1 permit 192.168.0.0 0.0.0.255
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 1 permit 192.168.2.0 0.0.0.255
ip nat inside source list 1 interface fa0/0 overload
R2
router ospf 1
network 192.168.1.254 0.0.0.0 area 0
R3
router ospf 1
network 192.168.0.2 0.0.0.0 area 0
network 192.168.2.254 0.0.0.0 area 0
Kind Regards
Paul
R1
hostname R1
ip address dhcp
ip nat outside
duplex auto
speed auto
ip nat inside
duplex auto
speed auto
router ospf 1
router-id 1.1.1.1
R2
hostname R2
ip dhcp pool LAN
duplex auto
speed auto
duplex auto
speed auto
router ospf 1
router-id 2.2.2.2
R3
hostname R3
duplex auto
speed auto
duplex auto
speed auto
router ospf 1
router-id 3.3.3.3
Thank you so much! I do need 3 different areas.
