Assign public ip to router interfaces
MAHESH.K
should i assign public ip provided by isp to router interfaces and firewall or only to firewall interfaces.
If you want to expose your firewall on public network directly, you can assign public IP to it and connect it with ISP. I would suggest you to assign public IP to your router and then connect this router to Firewall by using public IP (if you got an extra public ip block from ISP) or Private IP.
-Amit
johnd2310
Level 8
Level 8
Will need more info on your setup. Which device is directly connected to the ISP and how many addresses have you been allocated by the ISP?
John
**Please rate posts you find helpful**
can i assign private ip to firewall interfaces? or should i assign only public ip addresses to router and firewall interfaces?
-Amit
