Assigning IP address range on VLANs
I would like to dynamically assign a 10.1.1.0 /26 network to VLAN 1 on my DHCP server, is it possible to do this on the Cisco ASA 5500 or should I do this only on the server?
Hi Chris,
This should be possible. .
Looks like maximum number of DHCP client addresses varies depending on the license.Below links shows how to enable DHCP service on ASA.
http://www.cisco.com/c/en/us/td/docs/security/asa/asa82/configuration/guide/config/dhcp.html#wp1115485
Hope that helps
Najaf
Please rate when applicable or helpful !!!
Searching on the web, found this:
DHCP Router Config
conft# interface fa0/0
conft# ip address 200.1.1.2 255.255.255.0
conft# no shutdown
(config)# ip dhcp excluded-address 172.16.1.1 172.16.1.9
(config)# ip dhcp excluded-address 172.16.2.1 172.16.2.9
(config)# ip dhcp pool DATA
(dhcp-config)# network 172.16.2.0 255.255.255.0
(dhcp-config)# default-router 172.16.2.1
(dhcp-config)# dns-server 4.2.2.2
(dhcp-config)# exit
(config)# ip dhcp pool VOICE
(dhcp-config)# network 172.16.1.0 255.255.255.0
(dhcp-config)# default-router 172.16.1.1
(dhcp-config)# option 150 ip 172.16.1.1
(dhcp-config)# exit
(config)# ip route 172.16.1.0 255.255.255.0 200.1.1.1
(config)# ip route 172.16.2.0 255.255.255.0 200.1.1.1
Hi Chris,
Hope that helps
Najaf
