assigning privilege level automatically
jemekeren
hi..i have been using aaa authentication login default local and enter username user1 privilege level 15 password user1. i hope by login with that username that user will raise the level automatically when ssh /telnet. is the way i do is wrong? tx
paolo bevilacqua
Yes, that's the way it should work.
add a line that says:
aaa authorization exec default local none
