Assistance with IGMP Group Membership
mumbles202
Level 5
Level 5
I'm working on a 3650 w/ the following configuration but not seeing anything when I enter "show ip igmp groups" even though devices are attached that should be using multicast:
Router_3650#sh run
Building configuration...
Current configuration : 5889 bytes
 Last configuration change at 13:37:25 UTC Wed May 5 2021 by admin
version 16.6
no service pad
service password-encryption
no platform punt-keepalive disable-kernel-core
hostname Router_3650
vrf definition Mgmt-vrf
address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
no aaa new-model
switch 1 provision ws-c3650-24pd
ip routing
ip dhcp excluded-address 192.168.200.0 192.168.200.9
ip dhcp excluded-address 192.168.200.50 192.168.200.254
ip dhcp pool Router
 network 192.168.200.0 255.255.255.0
default-router 192.168.200.1
ip igmp snooping vlan 200 querier version 2
ip igmp snooping vlan 200 querier address 192.168.200.1
no ip igmp snooping vlan 1
no ip igmp snooping vlan 50
ip igmp snooping vlan 200 immediate-leave
no login on-success log
crypto pki trustpoint TP-self-signed-275486518
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-275486518
 revocation-check none
 rsakeypair TP-self-signed-275486518
crypto pki certificate chain TP-self-signed-275486518
diagnostic bootup level minimal
spanning-tree mode rapid-pvst
username admin privilege 15 secret 5 $1$MD3P$1tN7go01hfVhy5Slg8hdN
redundancy
  mode sso
 transceiver type all
  monitoring
vlan configuration 1,50,200
class-map match-any system-cpp-police-topology-control
  description Topology control
class-map match-any system-cpp-police-sw-forward
 description Sw forwarding, L2 LVX data, LOGGING
class-map match-any system-cpp-default
  description DHCP Snooping, EWLC control, EWCL data
class-map match-any system-cpp-police-sys-data
 description Learning cache ovfl, Crypto Control, Exception, EGR Exception, NFL SAMPLED DATA, RPF Failed
class-map match-any system-cpp-police-punt-webauth
  description Punt Webauth
class-map match-any system-cpp-police-l2lvx-control
  description L2 LVX control packets
class-map match-any system-cpp-police-forus
  description Forus Address resolution and Forus traffic
class-map match-any system-cpp-police-multicast-end-station
 description MCAST END STATION
 description Transit Traffic and MCAST Data
class-map match-any system-cpp-police-l2-control
  description L2 control
class-map match-any system-cpp-police-dot1x-auth
  description DOT1X Auth
class-map match-any system-cpp-police-data
 description ICMP redirect, ICMP_GEN and BROADCAST
class-map match-any system-cpp-police-stackwise-virt-control
 description Stackwise Virtual
class-map match-any non-client-nrt-class
class-map match-any system-cpp-police-routing-control
 description Routing control
class-map match-any system-cpp-police-protocol-snooping
 description Protocol snooping
class-map match-any system-cpp-police-system-critical
 description System Critical and Gold
policy-map system-cpp-policy
interface Loopback1
ip address 1.1.1.1 255.255.255.255
interface GigabitEthernet0/0
 vrf forwarding Mgmt-vrf
 no ip address
 shutdown
 negotiation auto
interface GigabitEthernet1/0/1
 switchport access vlan 200
 switchport mode access
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
 switchport access vlan 50
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet1/1/1
[interface GigabitEthernet1/1/2
interface TenGigabitEthernet1/1/3
interface TenGigabitEthernet1/1/4
interface Vlan1
 description MGMT
ip address 192.168.10.1 255.255.255.0
interface Vlan50
 description Cameras
 ip address 192.168.50.1 255.255.255.0
interface Vlan1200
 description Router
 ip address 192.168.200.1 255.255.255.0
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
control-plane
 service-policy input system-cpp-policy
line con 0
 login local
 stopbits 1
line aux 0
 stopbits 1
line vty 0 4
 login local
 transport input all
line vty 5 15
 login local
 transport input all
end
Am I missing something that's required?  Devices should be connected to the first 10 ports on the switch.
Giuseppe Larosa
Hello @mumbles202 ,
your device is configured for IGMP snooping only.
However, someone a multicast router or an IGMP snooping querier needs to send out periodic IGMP query messages so that hosts interested in multicast traffic can answer in each subnet / VLAN / broadcast domain.
So either you enable full IPv4 multicast routing using:
ip multicast routing
ip pim sparse-dense mode under each SVI interface (VLAN 50 for example and VLAN 200)
Or you enable the IGMP snooping querier at least in VLAN 50.
To be noted if the router connected to VLAN 200 is multicast enabled it is able to send queries in VLAN 200 but it cannot do it in VLAN 50.
When you enable PIM under an interface you are also enabling IGMP on the same interface.
Hope to help
Giuseppe
Thanks for the reply.  I only need IGMP working in vlan 200 which is where all the devices that need to be plugged in will be.  Do I need to add something else other than:
Hello @mumbles202 ,
if there is no multicast router in vlan 200 then you need the IGMP snooping querier and your proposed configuration is enough
Hope to help
Giuseppe
