ATM ADSL Trouble shooting!
neil grant
Hi Guys / Gals.
Thought I would start another tread as you all have been very very useful
Im having issues with a site basically the atm interface drops periodically and the ISP has confirmed the link as working fine (supposedly at 6Mb but clients at site are not seeing this even when router is up) I would like your advise to see if I am troubleshooting the issue correctly:
show int atm 0
ATM0 is up, line protocol is up
  Hardware is MPC ATMSAR (with Alcatel ADSL Module)
  MTU 4470 bytes, sub MTU 4470, BW 446 Kbit/sec, DLY 820 usec, <--------------------BW is this the actual bandwidth available to the router?
  Encapsulation ATM, loopback not set
  Encapsulation(s): AAL5  AAL2, PVC mode
  10 maximum active VCs, 1024 VCs per VP, 1 current VCCs
  VC Auto Creation Disabled.
  VC idle disconnect time: 300 seconds
  Last input never, output 00:00:00, output hang never
  Queueing strategy: Per VC Queueing
  5 minute input rate 1000 bits/sec, 3 packets/sec
  5 minute output rate 1000 bits/sec, 2 packets/sec
     7154 packets input, 628130 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     6764 packets output, 640759 bytes, 0 underruns
     2 output errors, 0 collisions, 0 interface resets
     0 unknown protocol drops
show dsl interface atm 0
ATM0
Alcatel 20190 chipset information
                ATU-R (DS)                      ATU-C (US)
Modem Status:    Showtime (DMTDSL_SHOWTIME)
DSL Mode:        ITU G.992.5 (ADSL2+) Annex A
ITU STD NUM:     0x03                            0x3
Chip Vendor ID:  'STMI'                          'TSTC'
Chip Vendor Specific:  0x0000                    0x0510
Chip Vendor Country:   0x0F                      0xB5
Modem Vendor ID: 'CSCO'                          'TSTC'
Modem Vendor Specific: 0x0000                    0x5100
Modem Vendor Country:  0xB5                      0xB5
Serial Number Near:    FCZ143293KG
Serial Number Far:     0000000000Chip ID:        C196P (1)
DFE BOM:         DFE3.0 Annex A (1)
Capacity Used:   57%                             100%
Noise Margin:    11.5 dB                         21.0 dB
Output Power:    20.0 dBm                        12.0 dBm
Attenuation:     25.0 dB                         11.0 dB
FEC ES Errors:   277                             34161
ES Errors:       227                             20763
SES Errors:      215                             15853
LOSES Errors:    31                              1018946
UES Errors:       0                              1018667
Defect Status:   None                            None
Last Fail Code:  None
Watchdog Counter: 0x1C
Watchdog Resets: 0
Selftest Result: 0x00
Subfunction:     0x00
Interrupts:      4443 (0 spurious)
PHY Access Err:  0
Activations:     31
LED Status:      ON
LED On Time:     100
LED Off Time:    100
Init FW:         init_AMR-3.0.014_no_bist.bin
Operation FW:    AMR-3.0.014.bin
FW Source:       embedded
FW Version:      3.0.14
                 DS Channel1      DS Channel0   US Channel1       US Channel0
Speed (kbps):             0             6656             0               446  <----------------------------- Speed Is this the what the router should be running at?
Cells:                    0              644             0            648061
Reed-Solomon EC:          0                3             0            228039
CRC Errors:               0                0             0            666995
Header Errors:            0                0             0             36077
Total BER:                0E-0           0E-0
Leakage Average BER:      0E-0           0E-0
Interleave Delay:         0               16             0                38
Bitswap:               enabled            enabled
Bitswap success:          0                   0
Bitswap failure:          0                   0
LOM Monitoring : Disabled
DMT Bits Per Bin
000: 0 0 0 0 0 0 0 2 4 5 6 7 7 8 8 8
010: 8 9 9 9 9 9 9 9 8 8 8 7 6 5 3 0
020: 0 2 2 3 5 5 6 7 7 8 8 8 8 9 8 9
030: 9 9 9 9 9 9 9 9 9 9 9 9 9 9 9 9
040: 9 9 9 9 9 9 8 9 9 9 9 9 9 9 8 8
050: 9 9 9 9 9 9 9 8 9 9 9 9 9 9 9 9
060: 8 8 9 9 9 9 9 8 8 7 8 8 8 8 8 8
070: 8 7 7 8 8 8 8 8 2 8 8 8 8 8 8 8
080: 8 8 8 7 8 8 8 8 8 8 7 5 2 7 7 8
090: 8 8 8 8 8 8 8 8 8 8 8 8 8 7 8 7
0A0: 6 4 7 8 8 7 6 8 8 8 8 8 8 8 7 7
0B0: 8 8 8 8 8 8 8 8 8 8 8 8 7 8 8 8
0C0: 7 8 8 8 8 8 8 8 7 7 7 7 7 7 7 7
0D0: 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7
0E0: 7 7 7 5 7 7 7 7 7 7 7 6 5 7 7 7
0F0: 7 7 7 6 2 5 5 4 0 0 0 5 5 3 5 6
100: 7 7 7 7 6 4 2 5 6 6 4 0 4 5 5 2
110: 4 5 6 6 5 5 5 4 2 0 0 2 4 5 5 4
120: 2 4 5 5 5 5 5 5 3 2 4 5 5 5 5 5
130: 5 5 5 5 5 5 5 5 5 5 2 2 5 5 5 5
140: 5 4 2 0 2 4 5 4 5 5 4 2 2 3 4 2
150: 2 0 0 0 0 2 3 4 4 4 4 4 2 0 0 3
160: 4 2 3 4 3 2 0 2 3 4 4 4 4 4 2 2
170: 4 4 4 4 4 3 2 0 0 2 3 2 2 2 2 2
180: 0 0 2 2 2 3 3 2 2 0 2 2 3 3 3 3
190: 3 2 2 2 2 2 2 2 2 2 0 0 2 2 2 2
1A0: 2 2 2 0 2 2 2 2 2 2 2 2 2 2 2 2
1B0: 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2
1C0: 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2
1D0: 2 2 2 2 2 2 2 0 2 2 2 2 2 2 2 2
1E0: 0 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2
1F0: 0 0 0 2 0 0 0 0 0 0 0 0 0 0 0 0
DSL: Training log buffer capability is not enabled
The interface seems to drop randomly for no specific reason I could be telneted to the device while pinging from another location, or just pinging.
provider has tested the line & confirmed as working.
Is the attenuation, noise margin acceptable? the configuration template is used on other sites without issue,
Any guidance on this matter would be very helpful.
show run in atm 0
Building configuration...
Current configuration : 132 bytes
interface ATM0
no ip address
no atm ilmi-keepalive
pvc 0/38
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
end
show run int d1
Current configuration : 306 bytes
interface Dialer1
ip unnumbered Loopback0
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap callin
ppp chap hostname xxxxx
ppp chap password 0 xxxx
ppp multilink
ppp multilink interleave
ppp multilink fragment delay 20
end
What is the correct method for viewing available bandwidth?
Cheers Neil
Regards Neil http://uk.linkedin.com/pub/neil-grant/20/5b0/267
mavespig
Level 3
Level 3
Hi Neil,
The speed on a DSL link is forced by the DSLAM and you can see it in show dsl interface:
So in this case you have a download speed of 6.6 Mbps and 446 kbps in upload.
The upload speed is inherited by the interface, so you will see this value under show interface atm.
Regarding noise margin and attenuation, you can use these values as reference:
Noise margin: the higher the better.
8-13 average, 14-22 good, 23-28 excellent. Under 8 dB the interface will loose synchronization, or it will not train up at all.
Attenuation: the lower the better.
20-30 excellent, 30-40 very good, 40-60 average.
In your case, you have an excellent attenuation value, but a lot of noise on the line, although it's within limits.
I also see a lot of CRC errors:
Are these errors incrementing?
I'd suggest to verify the output of show dsl interface on normal situation and when the line flaps.
Perhaps you may check with the ISP how the line react when you reduce the speed. With a lower speed the line will be less sensible to noise, hence more stable.
Try also to change the phone cable between router and wall plug, and verify if there may be any interference from electrical appliances close to the cable.
Hope this helps
Marco
Hello Marco,
Cheers for the response, im not whether or not the counters are incrementing, Does anyone know the command to reset the counters to Zero, if i do this on 2 sites then compare the 2. Splitter and cable will be replaced shortly.
I will also compare the versions of code.
Best Regards Neil
paolo bevilacqua
You should start updating ADSL firmware.
The access to it is different based if you have a support contract or not.
