04-08-2018 09:54 AM - edited 03-05-2019 10:14 AM
dears,
i have problem with configuring atm interfaces and multilink ppp , physicl links are up up and multilink interface is down down that problem at gns3 1.4.4
kindly i want your help to guess where is the problem
R3
R3(config)#do show ip inter brief
FastEthernet0/0 unassigned YES unset administratively down down
FastEthernet0/1 unassigned YES unset administratively down down
FastEthernet1/0 unassigned YES unset administratively down down
FastEthernet1/1 unassigned YES unset administratively down down
FastEthernet2/0 unassigned YES unset administratively down down
FastEthernet2/1 unassigned YES unset administratively down down
GigabitEthernet3/0 unassigned YES unset administratively down down
Serial4/0 unassigned YES unset administratively down down
Serial4/1 unassigned YES unset administratively down down
Serial4/2 unassigned YES unset administratively down down
Serial4/3 unassigned YES unset administratively down down
Serial4/4 unassigned YES unset administratively down down
Serial4/5 unassigned YES unset administratively down down
Serial4/6 unassigned YES unset administratively down down
Serial4/7 unassigned YES unset administratively down down
ATM5/0 unassigned YES unset up up
ATM5/0.1132 unassigned YES unset up up
ATM6/0 unassigned YES unset up up
ATM6/0.1132 unassigned YES unset up up
Multilink1 10.0.0.1 YES manual down down
Virtual-Access1 unassigned YES unset down down
Virtual-Template1 unassigned YES unset down down
R3(config)#do show run inter multilink 1
Building configuration...
Current configuration : 103 bytes
interface Multilink1
ip address 10.0.0.1 255.255.255.252
ppp multilink
ppp multilink group 1
end
R3(config)#do show run inter atm5/0.1132
Current configuration : 115 bytes
interface ATM5/0.1132 point-to-point
pvc 0/5
encapsulation aal5snap
protocol ppp Virtual-Template1
end
R3(config)#do show run inter atm6/0.1132
interface ATM6/0.1132 point-to-point
pvc 0/5
end
R3(config)#do show run inter virtual-temp 1
Current configuration : 88 bytes
interface Virtual-Template1
no ip address
ppp multilink
end
R4
R4(config)#do show ip inter brief
Multilink1 10.0.0.2 YES manual down down
R4(config)#do show run
Current configuration : 2313 bytes
upgrade fpd auto
version 12.4
hostname R4
boot-start-marker
boot-end-marker
logging message-counter syslog
no aaa new-model
ip source-route
ip cef
no ipv6 cef
voice dsp waitstate 0
memory-size iomem 0
archive
log config
hidekeys
ip address 10.0.0.2 255.255.255.252
ppp multilink
interface FastEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet1/0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet1/1
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet2/0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet2/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet3/0
no ip address
shutdown
negotiation auto
interface Serial4/0
no ip address
shutdown
serial restart-delay 0
interface Serial4/1
no ip address
shutdown
interface Serial4/2
no ip address
shutdown
interface Serial4/3
no ip address
shutdown
interface Serial4/4
no ip address
shutdown
interface Serial4/5
no ip address
shutdown
interface Serial4/6
no ip address
shutdown
interface Serial4/7
no ip address
shutdown
interface ATM5/0
no ip address
no atm ilmi-keepalive
pvc 0/35
interface ATM6/0
no ip address
pvc 0/35
no ip address
ppp multilink
ip forward-protocol nd
no ip http server
no ip http secure-server
logging alarm informational
control-plane
mgcp fax t38 ecm
gatekeeper
shutdown
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
login
end
atm switch
source port 1 0:5 destination port 2 0:35
sourec port 3 0:5 destination port 4 0:35
