ā03-15-2012 04:33 PM - edited ā03-04-2019 03:41 PM
I need to install an ATM module in a 3925 router. I would like to know if this card is that I have to buy with the transceiver(SFP)?
Will use a fiber cable LC LC singlemode fiber optic.
Module: NM-1A-OC3-POM
Transceiver :SFP-OC3-IR1
ā03-16-2012 12:14 AM
That will work. You also need a NM adapter for the ISR G2.
ā03-16-2012 01:40 AM
I would use this adapter where?
ā03-16-2012 08:46 AM
As mentioned before, in the 3925 ISR G2 router.
Please remember to rate useful posts clicking on the stars below.
ā03-16-2012 11:43 AM
Hi there.
3925 has 'SM' slots. The ATM card is a 'NM' card. You need a SM-NM adapter for the ISRG2.
Part number is SM-NM-ADPTR
Hope that helps,
Jamie
