atm ima card connection
ROMAN TOMASEK
Hi all,
I have one question. Is possible to connect ports on the IMA card to other IMA card in different order?? When I have ports on one end 1,2,3,4. Can I connect these ports on the other end in tho following order for example: 2,1,4,3?? Will it work?? Or I have to connect the ports in the same order (1,2,3,4)??
Thank you
Roman
paolo bevilacqua
You can connect in any order. The IMA protocol makes that transparent.
