All,
I am facing a problem with an ATM interface, the interface reads CRC and output drops, i've replaced the fiber cable but it still reads CRCs.
The remote end is a Cisco BPX 8620.
router#sh interfaces atM 2/0
ATM2/0 is up, line protocol is up
Hardware is ENHANCED ATM PA
MTU 4470 bytes, sub MTU 4470, BW 149760 Kbit, DLY 80 usec,
reliability 255/255, txload 27/255, rxload 28/255
Encapsulation ATM, loopback not set
Encapsulation(s): AAL5
4095 maximum active VCs, 482 current VCCs
VC idle disconnect time: 300 seconds
0 carrier transitions
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 17:01:19
Input queue: 2/75/0/21 (size/max/drops/flushes); Total output drops: 344367
Queueing strategy: Per VC Queueing
30 second input rate 16666000 bits/sec, 4204 packets/sec
30 second output rate 16021000 bits/sec, 4206 packets/sec
233529751 packets input, 2589359131 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 1 giants, 0 throttles
516 input errors, 531 CRC, 0 frame, 0 overrun, 92 ignored, 0 abort
232834136 packets output, 1945001564 bytes, 0 underruns
Thanks in advace.
