ATM Interface Up and Down
Phoungsakdavin
I configured my router 2621XM with WIC-1ADSL Card as a PPPOE client. It worked fine for about 1 week. But now it does not work. The problem is that the ATM interface is up and down again and again as shown below. Following is the config:
ras-01-sr#sh run
interface Loopback0
ip address xxxxxxxxxx
ip access-group 103 out
ip nat inside
ip tcp adjust-mss 1452
hold-queue 100 out
interface ATM0/0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
pvc 0/35
pppoe-client dial-pool-number 1
interface FastEthernet0/1
ip nat inside
duplex auto
speed auto
hold-queue 100 out
interface Async33
ip nat inside
encapsulation ppp
dialer in-band
dialer string xxxxxxxx
dialer-group 1
async mode dedicated
peer default ip address pool dialup
ppp authentication pap
hold-queue 100 out
interface Dialer1
ip address negotiated
ip access-group 111 in
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer remote-name redback
dialer-group 1
ppp authentication pap chap callin
ppp chap hostname xxxxxxxxxx
ppp chap password 7 xxxxxxxxxxxxxxx
ppp pap sent-username xxxxxxxxx password 7 xxxxxxxxxxxxx
ppp ipcp dns request
ppp ipcp wins request
ip local pool dialup xxxxxxxxxxxxx
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
access-list 102 permit ip 192.168.1.0 0.0.0.255 any
access-list 103 permit ip 192.168.0.0 0.0.0.255 any
access-list 103 permit ip any any
dialer-list 1 protocol ip permit
ras-01-sr#sh ip int brie
ATM0/0 unassigned YES NVRAM down down
FastEthernet0/1 xxxxxxxxxxxxx YES NVRAM up down
Async33 xxxxxx YES NVRAM up up
Dialer1 unassigned YES NVRAM up up
Loopback0 xxxxxx YES NVRAM up up
*Mar 1 16:11:56.028: %LINK-3-UPDOWN: Interface ATM0/0, changed state to up
*Mar 1 16:11:57.029: %LINEPROTO-5-UPDOWN: Line protocol on Interface ATM0/0, changed state to up
*Mar 1 16:12:04.662: %LINK-3-UPDOWN: Interface ATM0/0, changed state to down
*Mar 1 16:12:05.663: %LINEPROTO-5-UPDOWN: Line protocol on Interface ATM0/0, changed state to down
ras-01-sr#
*Mar 1 15:48:42.443: %LINK-3-UPDOWN: Interface ATM0/0, changed state to up
*Mar 1 15:48:43.445: %LINEPROTO-5-UPDOWN: Line protocol on Interface ATM0/0, changed state to up
*Mar 1 15:48:54.086: %LINK-3-UPDOWN: Interface ATM0/0, changed state to down
*Mar 1 15:48:55.088: %LINEPROTO-5-UPDOWN: Line protocol on Interface ATM0/0, changed state to down
*Mar 1 15:49:11.491: %LINK-3-UPDOWN: Interface ATM0/0, changed state to up
*Mar 1 15:49:12.492: %LINEPROTO-5-UPDOWN: Line protocol on Interface ATM0/0, changed state to up
*Mar 1 15:49:24.087: %LINK-3-UPDOWN: Interface ATM0/0, changed state to down
*Mar 1 15:49:25.089: %LINEPROTO-5-UPDOWN: Line protocol on Interface ATM0/0, changed state to down
*Mar 1 15:49:51.556: %LINK-3-UPDOWN: Interface ATM0/0, changed state to up
*Mar 1 15:49:52.558: %LINEPROTO-5-UPDOWN: Line protocol on Interface ATM0/0, changed state to up
*Mar 1 15:50:04.085: %LINK-3-UPDOWN: Interface ATM0/0, changed state to down
*Mar 1 15:50:05.087: %LINEPROTO-5-UPDOWN: Line protocol on Interface ATM0/0, changed state to down
end
Note: The line and configuratoin still keeping the same as it works before. DSLAM is HUAWEI MA5100.
I am not sure why it causes the problem weirdly.
Any feedback or reply would be appreciated.
VIN
arvindchari
Level 3
Level 3
Could you post the contents of the
show controllers atm mod/slot command here? The counters contained therein would provide a better clue with respect to why the link might be flapping
Also, in case you havent already, check for the physical layer alarms using the LED's
Thanks for your reply.
ras-01-sr#sh int
ATM0/0 is down, line protocol is down
Hardware is DSLSAR (with Alcatel ADSL Module)
MTU 4470 bytes, sub MTU 4470, BW 32 Kbit, DLY 16000 usec,
reliability 5/255, txload 1/255, rxload 1/255
Encapsulation ATM, loopback not set
Encapsulation(s): AAL5 AAL2, PVC mode
23 maximum active VCs, 256 VCs per VP, 0 current VCCs
VC Auto Creation Disabled.
VC idle disconnect time: 300 seconds
Last input never, output 00:29:31, output hang never
ast clearing of "show interface" counters never Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 7 Queueing strategy: Per VC Queueing
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
1 packets output, 70 bytes, 0 underruns
0output buffer failures, 0 output buffers swapped out
This is the ATM Interface when it was up.
ATM0/0 is up, line protocol is up
reliability 10/255, txload 1/255, rxload 1/255
Last input never, output 00:00:41, output hang never
2 packets output, 140 bytes, 0 underruns
Note: I have noticed that when i plug the line into the card,the CD LED start blinking and then stop. When the LED stop blinking the interface is up. For 3 second, the CD LED start blinking again and then the atm interface is down.
Any possible solution to fix this problem?
VIN
Could you also post the output of debug atm errrors command ?
Router#terminal monitor
Router#debug atm event
Im just wondering if CD stands for Carrier Detect and a blinking CD means no carrier.
That being the case, physically unplug the ADSL Cable (RJ-11) from the Cisco ADSL WIC ADSL interface. Wait for a few seconds. Plug the cable back in to cause the ADSL line to retrain.
Hi Arvind,
Sorry for late reply.
Please find the attached file to get the atm debug.
Please give me any advice on this.
VIN
