Attenuation Factor
devulapalli_h
Can you please explain how can we determine which capacity attenuator is suitable for a given router (eg 7200 series),and please also brief what is the significance of attenuator in router environment.Thanks
paolo bevilacqua
It is used to avoid saturating or damaging receiver on optical and some electrical interfaces.
The specifics are different for each exact type of interface.
Please rate post if it helps!
