AUDIT-5-RUN_CONFIG - Running Configuration changed. Hash: 0192D51F86DD339013527E8946F4AED6
Tony Riccardi
I have a 4507-R in production which constantly spits out the following log messages (also see attached):
Feb 27 10:28:34.676 GMT: %AUDIT-5-RUN_CONFIG: Running Configuration changed. Hash: DF73ECD05BB4F88573B05A0C89E16F23
Feb 27 10:53:13.236 GMT: %AUDIT-1-FILE_ROLLOVER: Audit File Roll-over: 3
Feb 27 10:53:13.236 GMT: %AUDIT-5-RUN_CONFIG: Running Configuration changed. Hash: 0192D51F86DD339013527E8946F4AED6
Feb 27 10:58:09.527 GMT: %AUDIT-5-RUN_CONFIG: Running Configuration changed. Hash: 171BBA5FA70C775784425B107E306930
Feb 27 11:22:39.568 GMT: %AUDIT-5-RUN_CONFIG: Running Configuration changed. Hash: 29DE484FD5F2C24B6B6876A092477201
Feb 27 11:32:32.921 GMT: %AUDIT-5-RUN_CONFIG: Running Configuration changed. Hash: 1326587382BAC182963AB7B00139FF97
Feb 27 11:52:20.939 GMT: %AUDIT-5-RUN_CONFIG: Running Configuration changed. Hash: 04796F68897A26B16E60F587D04AFAA0
Here are the details of the router and its directory:
Cisco IOS Software, Catalyst 4000 L3 Switch Software (cat4000-I5K91S-M), Version
12.2(25)EWA14, RELEASE SOFTWARE (fc1)
Image text-base: 0x10000000, data-base: 0x115CE0AC
ROM: 12.2(20r)EW1
Dagobah Revision 226, Swamp Revision 34
ROUTER uptime is 1 week, 5 days, 7 hours, 14 minutes
Uptime for this control processor is 1 week, 5 days, 7 hours, 15 minutes
System restarted at 03:01:12 GMT Sun Feb 19 2012
System image file is "bootflash:"
cisco WS-C4507R (MPC8245) processor (revision 4) with 524288K bytes of memory.
Processor board ID FOX11290MTP
MPC8245 CPU at 400Mhz, Supervisor V
Last reset from PowerUp
511K bytes of non-volatile configuration memory.
Configuration register is 0x2101
Directory of bootflash:/
    1  -rwx    12939640  Nov 15 2008 19:33:04 +00:00  cat4000-i5k91s-mz.122-25.E
WA14.bin
59244544 bytes total (46304776 bytes free)
Config file compression is also enabled.
No other 4507 is displaying these log messages.
Has anyone seen this issue before and know how to resolve it?
0 Replies 0
