888 router and bounded 2 SHDSL lines conf issue
methos365
Hello to All,
i am trying to implement a 4-wire shdsl line (2 shdsl lines - bounded) to a cisco 888 router with the below configuration but the line is not getting synchronized.
controller DSL 0
mode atm
line-term cpe
line-mode 4-wire enhanced
dsl-mode shdsl symmetric annex A-B
line-rate 4608
IOS ver is 12.4(15)T7
Could you please advice on this? Do you think there are different solutions?
Thank you in advance for your time!
Tasos
mavespig
Level 3
Level 3
Hi Anastasios,
You wrote that the link is "2 shdsl lines - bounded". Do you mean that the ISP is providing two different links, each with 1 pair?
Can you try to configure line-mode, dsl-mode and line-rate to auto? It is possible that the ISP is sending something different that what you configured.
Hope this helps
Marco
Hello Macro,
thank you for your reply,
2 different shdsl lines are terminated to my building and using a 4-wire cable these lines are bonded to one. Appropriate configuration is applied by the ISP (as i was told) at the DSLAM for this implementation. So its 2 different links (local loops) with one pair each.
i will try the auto option and i will come back.
thank you again..
