Authenticate switch using ISE server
s-lach1001
Hello everyone, I am trying to configure my switch so everyone who has an account on my AD can log in using ISE authentification server and here is the configuration in one switch:
SW-IDF-1F-B#sh conf
Using 13014 out of 2097152 bytes
! Last configuration change at 08:05:55 UTC Wed Apr 23 2025 by network-admin
version 17.6
service call-home
platform punt-keepalive disable-kernel-core
hostname SW-IDF-1F-B
vrf definition Mgmt-vrf
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
enable secret 9 $14$LbzO$KVPsG.r1hOuhVU$CPhnWwZBh1UUt.LqGCcVGD2nBT429VxntrxplR1mx8s
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa server radius dynamic-author
aaa session-id common
switch 1 provision c9200l-48p-4x
no ip domain lookup
ip domain name ICESCO.LAN
login on-success log
crypto pki trustpoint SLA-TrustPoint
 enrollment pkcs12
 revocation-check crl
crypto pki trustpoint TP-self-signed-3252691763
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-3252691763
 revocation-check none
 rsakeypair TP-self-signed-3252691763
crypto pki certificate chain SLA-TrustPoint
 certificate ca 01 nvram:CiscoLicensi#1CA.cer
crypto pki certificate chain TP-self-signed-3252691763
 certificate self-signed 01 nvram:IOS-Self-Sig#2.cer
license boot level network-essentials addon dna-essentials
diagnostic bootup level minimal
spanning-tree mode rapid-pvst
memory free low-watermark processor 10633
username o.abdelalim privilege 15 secret 9 $14$uu1e$k3DyyIlwzwtkyk$ABFm8z6y.LsVrGimcW.fUlRU.BX24e8uJKzYWtAd/T6
username network-admin privilege 15 secret 9 $9$bW2TAR.6QG4vC.$F70n8HMOahFIoZjkpSI40Swk717N4s4thn3CoLtDmEU
username cisco privilege 15 secret 9 $9$3/MI2F6M2/II2E$Ol78zc2augvgNh.tZHV3eTLzgic22cLzKKvSLL3pndY
redundancy
 mode sso
transceiver type all
 monitoring
lldp run
class-map match-any system-cpp-police-ewlc-control
  description EWLC Control
class-map match-any system-cpp-police-topology-control
  description Topology control
class-map match-any system-cpp-police-sw-forward
  description Sw forwarding, L2 LVX data packets, LOGGING, Transit Traffic
class-map match-any system-cpp-default
  description EWLC data, Inter FED Traffic
class-map match-any system-cpp-police-sys-data
  description Openflow, Exception, EGR Exception, NFL Sampled Data, RPF Failed
class-map match-any system-cpp-police-punt-webauth
  description Punt Webauth
class-map match-any system-cpp-police-l2lvx-control
  description L2 LVX control packets
class-map match-any system-cpp-police-forus
  description Forus Address resolution and Forus traffic
class-map match-any system-cpp-police-multicast-end-station
  description MCAST END STATION
class-map match-any system-cpp-police-high-rate-app
  description High Rate Applications
  description MCAST Data
class-map match-any system-cpp-police-l2-control
  description L2 control
class-map match-any system-cpp-police-dot1x-auth
  description DOT1X Auth
class-map match-any system-cpp-police-data
  description ICMP redirect, ICMP_GEN and BROADCAST
class-map match-any system-cpp-police-stackwise-virt-control
  description Stackwise Virtual OOB
class-map match-any non-client-nrt-class
class-map match-any system-cpp-police-routing-control
  description Routing control and Low Latency
class-map match-any system-cpp-police-protocol-snooping
  description Protocol snooping
class-map match-any system-cpp-police-dhcp-snooping
  description DHCP snooping
class-map match-any system-cpp-police-ios-routing
  description L2 control, Topology control, Routing control, Low Latency
class-map match-any system-cpp-police-system-critical
  description System Critical and Gold Pkt
class-map match-any system-cpp-police-ios-feature
  description ICMPGEN,BROADCAST,ICMP,L2LVXCntrl,ProtoSnoop,PuntWebauth,MCASTData,Transit,DOT1XAuth,Swfwd,LOGGING,L2LVXData,ForusTraffic,ForusARP,McastEndStn,Openflow,Exception,EGRExcption,NflSampled,RpfFailed
policy-map system-cpp-policy
interface GigabitEthernet0/0
 vrf forwarding Mgmt-vrf
 no ip address
 shutdown
interface GigabitEthernet1/0/1
 description Non-Arabic
 switchport access vlan 110
 switchport mode access
 switchport voice vlan 150
 spanning-tree portfast
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
 switchport trunk native vlan 201
 switchport nonegotiate
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
 description DT
 switchport access vlan 122
interface GigabitEthernet1/0/25
 description DT
interface GigabitEthernet1/0/26
 description DT
interface GigabitEthernet1/0/27
 description DT
interface GigabitEthernet1/0/28
 description DT
interface GigabitEthernet1/0/29
 description DT
interface GigabitEthernet1/0/30
 description DT
interface GigabitEthernet1/0/31
 description DT
interface GigabitEthernet1/0/32
 description DT
interface GigabitEthernet1/0/33
 description DT
interface GigabitEthernet1/0/34
 description DT
interface GigabitEthernet1/0/35
 description DT
interface GigabitEthernet1/0/36
 description DT
interface GigabitEthernet1/0/37
 description DT
interface GigabitEthernet1/0/38
 description DT
interface GigabitEthernet1/0/39
 description DT
interface GigabitEthernet1/0/40
 description DT
interface GigabitEthernet1/0/41
 description DT
interface GigabitEthernet1/0/42
 description DT
 switchport trunk native vlan 200
interface GigabitEthernet1/0/43
 description VLAN-PRINTER
 switchport access vlan 210
interface GigabitEthernet1/0/44
interface GigabitEthernet1/0/45
interface GigabitEthernet1/0/46
 description VLAN-AP
 switchport mode trunk
interface GigabitEthernet1/0/47
 description VLAN-AP
interface GigabitEthernet1/0/48
 description VLAN-AP
interface TenGigabitEthernet1/1/1
 description UPLINK
interface TenGigabitEthernet1/1/2
 description UPLINK
interface TenGigabitEthernet1/1/3
 description UPLINK
interface TenGigabitEthernet1/1/4
 description UPLINK
interface Vlan1
 no ip address
 shutdown
interface Vlan24
 ip address 172.24.24.41 255.255.255.0
ip default-gateway 172.24.24.254
ip forward-protocol nd
no ip http server
ip http authentication local
ip http secure-server
logging host 10.1.13.71 transport udp port 8516
snmp-server community IcE$c0!2022 RO
snmp-server community ICESCO RW
snmp-server host 10.1.10.215 version 2c IcE$c0!2022
control-plane
 service-policy input system-cpp-policy
line con 0
 logging synchronous
 stopbits 1
line aux 0
line vty 0 4
 logging synchronous
 transport input ssh
line vty 5 15
 logging synchronous
 transport input ssh
ntp server 10.1.10.107
call-home
 ! If contact email address in call-home is configured as sch-smart-licensing@cisco.com
 ! the email address configured in Cisco Smart License Portal will be used as contact email address to send SCH notifications.
 contact-email-addr sch-smart-licensing@cisco.com
 profile "CiscoTAC-1"
  active
  destination transport-method http
end
marce1000
  - Your configuration is missing many items for that to work ; have a look at :
         https://www.cisco.com/en/US/docs/security/ise/1.0/user_guide/ise10_sw_cnfg.pdf
  M.
