Auto QoS on Metro Ethernet with 2911 Routers
mike.welker
Hi all,
We use a somewhat unique Metro Ethernet WAN, in which all links are 12Mbps, point to point metro ethernet links, but connected between two 2911 ISR G2 routers, rather than switches.  These routers are connected to 3750 stacks on the LAN side.
We are setting up Cisco VoIP, and while all of our LAN switches have the proper Auto QoS statements ("auto qos voip cisco-phone" on access ports, and "auto qos voip trust" on trunk ports, including the ports connecting to the router), it does not appear that any of these settings can be applied to the router's gigabit ethernet interfaces.  A separate VLAN has been set up for our voice subnet already at our pilot site.
My research thus far appears to indicate that auto QoS cannot be applied to ethernet interfaces on a router in general.  Our carrier does not strip or filter out any qos markings, but setting up switch-to-switch connections is not currently feasible in the scope of the project right now.
Am I simply out of luck with using Auto QoS in our current topology?  Is there a way to trunk voice traffic, with the QoS mrakings from the switch, through the router itself?
Thank you for any help.
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
You're off to a good start.
If your logical bandwidth is only 12 Mbps, you probably should shape for that and use a subordinate policy to prioritize your VoIP.  (Actually, if you can, you might consider running both interfaces physically at 10 Mbps - QoS works a bit better with the physical bandwidth of an interface rather than using a shaper.)
I would also recommend enabling FQ in class-default, for all your other non-VoIP traffic, and for traffic-like VoIP, you normally use LLQ.
E.g.
policy-map ShapeMetroE
class class-default
!you may need to shape lower than nominal 12 Mbps to allow for L2 overhead
!I've set to 10 Mbps to insure shaper controls bandwidth
!so we can insure priority treatment for VoIP
shape average 10000000
service-policy VoIP
policy-map VoIP
class VOIP
priority percent 30
class class-default
fair-queue
int g0/1
service-policy output ShapeMetroE
tx-ring-limit 3 !shouldn't be needed with a shaper - but if you do set interface to 10 Mbps
Lei Tian
Hi Mike,
You don't really need QoS on the LAN facing interface. The router trust QoS setting by default. However, you should config QoS on the metro-E interface, and you need to use H-QoS on that interface.
http://www.cisco.com/en/US/docs/ios-xml/ios/qos_hrhqf/configuration/15-mt/qos-hrhqf.html
HTH,
Lei Tian
Thank you, I figured it would be a little more involved than Auto QoS.
So, given a Cisco Call Manager System, and Cisco 2911 Routers with Metro Ethernet circuits between them, would something similar to the following configuration (done on my lab router) be the way to go?  I arbitrarily picked 30 percent of a link as the bandwidth.
I attempted to match the class-map of VOIP to VLAN 120, but it did not like that when I ultimatley applied it to Gig0/1.  Thus, I've changed it to match the RTP protocol.
class-map match-all VOIP
  description Voice QoS Class Map
match protocol rtp audio
policy-map VoIP
class VOIP
  bandwidth percent 30
interface GigabitEthernet0/0
description DATA VLAN
ip address 10.10.10.1 255.255.0.0
duplex auto
speed auto
interface GigabitEthernet0/0.120
description VOICE VLAN
encapsulation dot1Q 120
ip address 10.120.0.1 255.255.0.0
interface GigabitEthernet0/1
description METRO ETHERNET
ip address 10.40.1.1 255.255.255.0
duplex auto
speed auto
service-policy output VoIP
end
Disclaimer
Posting
E.g.
class class-default
service-policy VoIP
policy-map VoIP
class VOIP
priority percent 30
class class-default
fair-queue
int g0/1
