auto QoS
leungcm
We would like to implement the QoS to E1 circuit. Do we enable both sides? or only end? please advise
Best regards
Jon Marshall
Generally speaking you would enable it on both ends of the circuit.
Jon
QoS should be end to end and in both directions to work properly
Narayan
You need enable every hop along the path that the QOS traffics go.In your case you would do as Jon stated.
Hope this help.
Thot
thanks all of you
