Auto-summarization disabled in EIGRP on IP-Base 3560
Mierdin21
I'm running IP Base on my Catalyst 3560. I'm aware of the fact that this license only allows for EIGRP stub routing - this is desired. However, I don't seem to be able to run the "no auto" command to disable auto-summarization. The command works, but doesn't make it into the running config.
3560-1(config-router)#no eigrp stub connected
     EIGRP is restricted to stub configurations only on this platform.
3560-1(config-router)#no auto
3560-1(config-router)#do show run | b router
router eigrp 1
     network 10.24.0.0 0.0.255.255
     passive-interface default
     no passive-interface GigabitEthernet0/24
Not a huge deal since a "show ip prot" indicates that auto-summarization is already disabled, so I'm guessing this is why "no auto" will not take. Can anyone point me to a whitepaper or article explaining why auto-summarization is disabled by default in my scenario?
Thanks!
Raju Sekharan
Auto-summary is disbaled by default in newer codes.
In such cases  you don't see it in the configuration
http://www.cisco.com/en/US/docs/ios/iproute_eigrp/command/reference/ire_a1.html#wp1062919
