Automatic clearence of interface counter
Sudeb Das
As we all know #clear counters interface -  command will clear interface stats. Now if the counter automatically clears & interface stats reset after few seconds then how can we solve the problem.
As per my scenario - Everytime I run #show interface f0/0/12 - command on my switch the stats reset all information. e.g. packet input output, broadcast everything. I never seen these with a increment value. Now what causes the interface counter to reset ????????
There are no duplex, speed mismatch. No Qos applied. This is a trunk port. Operation is normal though & other ports are showing correct info for all counter. Please suggest what should I check ?
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Assuming you're not looking at down ports, it could be a bug.
What's the device and its IOS image?
