Automation script
sas2k3001
Is it possible to run the script with the command?
show int g0/0.(variable from VLAN list)
I need to take details of more than 4000 sub interfaces
Jon Marshall
Not much detail to go on ie. what are you using to connect to the device etc.
I use Python and Netmiko so if I was doing it I would probably just do a "sh run" on the device and then parse the output grabbing the information I needed from each interface but like I say you don't really give much detail.
Jon
Hi @Jon Marshall
I connecting with SSH to the device.
inderdeeps
Level 4
Level 4
@sas2k3001 : Check this out
targets = []
for m1 in re.finditer("(GigabitEthernet\d.\d.\d+).*?buffers swapped out", cli_input, re.DOTALL):
        m2 = re.search("(?P<interface>GigabitEthernet\d.\d.\d+).*Last input never", m1.group(0), re.DOTALL)
        if m2:
            targets.append(m2.group("interface"))
print(targets)
