Trouble with ACL for Cryptomap/site to site vpn
Oeohfppe
Good morning,
I am running into a problem with I think the ACL I have set up for this VPN. The goal, is to allow one host 192.168.33.9 to communicate with a printer over a vpn tunnel. I have this set up at 3 other locations with different equipment at it works fine. In running the command show crypto isakmp sa, it shows the tunnel as active, show crypto ipsec sa shows the tunnel as active.
This configuration is on a  ISR 4321 (trouble site) we have ASAs at the three sites that work.
This is why I think it is an ACL issue. What I have configured for this VPN,
access-list 130 permit ip host 192.168.33.9 host H.H.H.H
crypto map VPNmap 130 ipsec-isakmp
description Tunnel to RRVR
set peer R.R.R.R
set transform-set ESP-AES256-SHA1
match address 130
Thanks for your time, I deeply appreciate your assistance.
2 Accepted Solutions
Jon Marshall
In addition to what the others have suggested have you done a NAT exemption for the VPN tunnel traffic ?
Jon
7 Replies 7
balaji.bandi
what is the Logs show and what i other side config ?
also post as mentioned your tunnel up ?
BB
What logs would you like to see, I am not at all familiar with the ISR or the IOS.
ISR-GW1#show crypto isakmp sa
IPv4 Crypto ISAKMP SA
dst src state conn-id status
L.L.L.L X.X.X.X QM_IDLE 13044 ACTIVE
L.L.L.L R.R.R.R QM_IDLE 13043 ACTIVE
L.L.L.L X.X.X.X QM_IDLE 13042 ACTIVE
IPv6 Crypto ISAKMP SA
#show crypto ipsec sa
interface: GigabitEthernet0/0/0
Crypto map tag: VPNmap, local addr L.L.L.L
protected vrf: (none)
local ident (addr/mask/prot/port): (192.168.32.0/255.255.248.0/0/0)
remote ident (addr/mask/prot/port): (192.168.4.0/255.255.254.0/0/0)
current_peer X.X.X.X port 500
PERMIT, flags={origin_is_acl,}
#pkts encaps: 404691252, #pkts encrypt: 404691252, #pkts digest: 404691252
#pkts decaps: 262974473, #pkts decrypt: 262974473, #pkts verify: 262974473
#pkts compressed: 0, #pkts decompressed: 0
#pkts not compressed: 0, #pkts compr. failed: 0
#pkts not decompressed: 0, #pkts decompress failed: 0
#send errors 0, #recv errors 0
local crypto endpt.: L.L.L.L, remote crypto endpt.: X.X.X.X
plaintext mtu 1438, path mtu 1500, ip mtu 1500, ip mtu idb GigabitEthernet0 /0/0
current outbound spi: 0x6B62317E(1801597310)
PFS (Y/N): N, DH group: none
inbound esp sas:
spi: 0xC354FF86(3277127558)
transform: esp-256-aes esp-sha-hmac ,
in use settings ={Tunnel, }
conn id: 6313, flow_id: ESG:4313, sibling_flags FFFFFFFF80004048, crypto map: VPNmap
sa timing: remaining key lifetime (k/sec): (4605922/2548)
IV size: 16 bytes
replay detection support: Y
Status: ACTIVE(ACTIVE)
inbound ah sas:
inbound pcp sas:
outbound esp sas:
conn id: 6314, flow_id: ESG:4314, sibling_flags FFFFFFFF80004048, crypto map: VPNmap
sa timing: remaining key lifetime (k/sec): (4605744/2548)
IV size: 16 bytes
outbound ah sas:
outbound pcp sas:
remote ident (addr/mask/prot/port): (192.168.8.0/255.255.254.0/0/0)
#pkts encaps: 5580685, #pkts encrypt: 5580685, #pkts digest: 5580685
#pkts decaps: 4498351, #pkts decrypt: 4498351, #pkts verify: 4498351
plaintext mtu 1438, path mtu 1500, ip mtu 1500, ip mtu idb GigabitEthernet0/0/0
current outbound spi: 0x22AB76B1(581662385)
inbound esp sas:
spi: 0xB193279B(2979211163)
conn id: 6311, flow_id: ESG:4311, sibling_flags FFFFFFFF80004048, crypto map: VPNmap
sa timing: remaining key lifetime (k/sec): (4605109/1057)
IV size: 16 bytes
inbound ah sas:
inbound pcp sas:
outbound esp sas:
conn id: 6312, flow_id: ESG:4312, sibling_flags FFFFFFFF80004048, crypto map: VPNmap
sa timing: remaining key lifetime (k/sec): (4599545/1057)
IV size: 16 bytes
outbound ah sas:
outbound pcp sas:
local ident (addr/mask/prot/port): (192.168.33.9/255.255.255.255/0/0)
remote ident (addr/mask/prot/port): (H.H.H.H/255.255.255.255/0/0)
current_peer R.R.R.R port 500
#pkts encaps: 0, #pkts encrypt: 0, #pkts digest: 0
#pkts decaps: 0, #pkts decrypt: 0, #pkts verify: 0
local crypto endpt.: L.L.L.L, remote crypto endpt.: R.R.R.R
current outbound spi: 0x12E03C24(316685348)
inbound esp sas:
spi: 0x289AD8EB(681236715)
conn id: 6315, flow_id: ESG:4315, sibling_flags FFFFFFFF80000048, crypto map: VPNmap
sa timing: remaining key lifetime (k/sec): (4608000/3274)
IV size: 16 bytes
inbound ah sas:
inbound pcp sas:
outbound esp sas:
conn id: 6316, flow_id: ESG:4316, sibling_flags FFFFFFFF80000048, crypto map: VPNmap
IV size: 16 bytes
outbound ah sas:
outbound pcp sas:
plaintext mtu 1500, path mtu 1500, ip mtu 1500, ip mtu idb GigabitEthernet0/0/0
current outbound spi: 0x0(0)
inbound esp sas:
inbound ah sas:
inbound pcp sas:
outbound esp sas:
outbound ah sas:
outbound pcp sas:
I have seen it a few times where the legacy (outdated) crypto maps don't work well, you might want to try a SVTI. This needs to be set up on both sides...what equipment do you have on the other side ?
I have no control over the other side, as it is a vendor's site. I will however look into SVTI, (not familiar with the term) to see if that might provide some help.
Jon Marshall
Jon
Jon,
First thank you for your assistance. In the instructions I found there was no mention of NAT, which from setting up the three ASA I found strange. Can you provide an example of of the NAT exemption for the VPN tunnel you are talking about or a link to documentation about this? In the meantime, it is off to the great oracle google.
